How we added almost free TV
Discussion in 'Campsite Electronics' started by Kampus, Apr 30, 2019.
  1. Kampus
    Kampus Active Member
    127
    108
    Jun 16, 2017
    Slate Belt, Pa
    This is going to be a little bit of a long read, but I figured other ATT, DirectTV customers may benefit.
    The DW and I enjoy the outdoors, but when the weather is bad or we turn in for the night, we enjoy a little TV. Previously we packed a small 8" TV and a thumbdrive with some downloaded shows on it that plugged into the TV....it worked pretty good until we were stuck inside for an entire trip due to the weather.
    We started thinking outside the box and found a way to get live TV in the camper using things we already had....we only needed to purchase a 150Watt inverter since we usually boondock ($16).
    So while it is not totally free, after the inverter purchase it cost us nothing additional.
    Here is what is needed:
    1. Be a DirecTV and ATT cellular customer. We have Direct TV at home and have ATT cell phone plans. This combination allows to the stream a bunch of live channels without using any data. Using the DirectTV app, you can watch the live TV on your phone for free.
    If you want to take advantage of this on a bigger screen...
    2. 19" LED flatscreen TV. This is the TV we normally use in out kitchen. It weighs nothing. We will just grab and pack it when we leave for a trip.
    2. Amazon fire stick (a Roku or Chromecast would probably work as well). We already own this and it is already connected to our kitchen TV
    3. a small wireless router. I cannot rave enough about the HooToo tripmate. I already owned this from when I used to travel for work. Not only is it tiny, its USB powered, and has a USB port and app you can use to access and watch downloaded content from a thumbdrive. Love it. Cost about $20.
    How to put it all together....
    The Amazon firestick is connected to the TV. Our phones (Samsung Galaxy 9 and 10) allow screen mirroring, as does the firestick. Both phone and firestick need to be on the same network to work. This is where the HooToo comes in. Connect the firestick to the HooToo, connect the phone to the HooToo, now they are on the same network. Make sure mobile data is turned on on your phone, turn on mirroring on both phone and firestick, open the direcTV app, watch your live TV fullscreen on the TV using mirroring. This has worked great for us so far.
    We added an inverter so we can run it off the deep cycle battery. As well as added a USB charger to run the firestick and charge the phone will streaming live. We mounted all this mess to the back of the TV for less clutter and ease of moving the TV between the house and the camper.
    It sounds like a process, but its really not....figured some others may get some use out of a similar setup.
    Orchid and Sjm9911 like this.
  2. Sneezer
    1,370
    399
    Keep an eye out for a tv that runs off 12v. They are out there and would be better on the battery than the inverter.
    I don't boondock so I always have power. We don't have cable at the house so we rely on downloaded movies from Netflix/Amazon. So far so good. I am looking at getting a Chromecast or fire stick though to experiment with.
  3. roybraddy
    roybraddy Well-Known Member
    1,937
    584
    Mar 23, 2016
    King George, Virginia
    Those TV sets that use a 120V Brick will run on 12VDC pretty good as well... Found an adapter DC plug back when Radio Shack was still running... AMAZON will have the right adapter plug as well... Those TV Bricks put out around 15VDC or so that plugs into the TV set. It works great from the 12.5-6 VDC directly from the battery or from the 13.6VDC or higher smart mode DC voltages from the smart mode converters just fine as well...
    Of course if your TV is wired directly using a standard 120V Cable then the small wattage 'PURE SINE WAVE' Power inverter works good too like the OP here used... If you use one of those MSW type power inverters your TV sets Viewing and sound will be affected all the time... Works good on PSW type Power Inverters...
    In my case I do a lot of running different things in my OFF-ROAD POPUP so I have what I call 'MY DUTY' PSW Power Inverter that is always on. It is rated at 600WATTs AIMS MODEL from AMAZON... I ran two multi-tap extension cords from it with one going to the home entertainment area and the other one going back to the cabinet top near the TENT bed area where we sleep... Being always On makes it great to plug in anything to it and not worry about them going up in the infamous blue smoke since the Power Inverter is a PURE SINE WAVE model... Usually use up to 150Watts is about all we ever use at any given time... Nice having the reserve power if needed... PSW Power inverters are cheap these days as compared to some 10 or so years back...
    Great for running our Mr Coffee grinder when brewing bean coffee on our Coleman Stove Top Drip Percolator when we are too lazy to startup the 2KW generator to run our Cuisinart Grind and Brew bean coffee maker...
    Always fine a way to do things hehe... We camp off grid with no shore power almost 90% of the time...
    Being a Ham radio guy however one the downsides to using the small 'low cost' Power Inverters is they are known to put off a lot of Burrr's and RF Noise all over the HF Ham Radio bands that you have to deal with...
    We watch TV too when camping... I put up a BATWING ANTENNA on the side of my camper and use a 24-inch HDTV in the trailer... Most always fine a OTA station somewhere when camping off grid..
    Roy's image
    Roy Ken
  4. xvz12
    xvz12 Well-Known Member
    732
    367
    Apr 6, 2017
    New Plymouth, ID
    We're generally far enough away from civilization that over-the-air TV is a no-go, but we have a small media box, a 19" monitor, & a USB stick that I've put movies & TV shows on for the times that we want to watch something...works pretty well, as long as the wife tells me what she wants to watch before we leave home....lol
  5. Sjm9911
    3,023
    1,301
    I might have to get the small wireless router. I did think of using a fire stick, or roku stick. But forgot that it needed a router!
    Orchid likes this.
  6. erich82
    erich82 Active Member
    128
    59
    Mar 12, 2019
    All this and you can just get an hdmi adapter for most phones, and youd save on hooking up a router and a chromecast. Or just bring a laptop or a tablet, which actually has a battery vs a TV.
  7. Chloe
    Chloe Active Member
    144
    38
    Jun 16, 2017
    Massachusetts
    This is a neat idea. We have DTV but our phones are on Sprint. I think we can still stream DTV... and we have unlimited data with Sprint, assuming we can get a signal, though.
    I load up my iPad with downloads from Netflix and also have stuff on my laptop (which is easier for 2 ppl watching).
  8. erich82
    128
    59
    Mar 12, 2019
    They also sell portable projectors (think pocket size) if you really want to go big and portable, although the image quality isn't top notch.
  9. Kampus
    127
    108
    Jun 16, 2017
    Slate Belt, Pa
    Im not sure if my phone supports this....it probably does. I had that little travel router from when I used to travel for work....it was great having your only little hot spot in a hotel room. It was just sitting around collecting dust.
  10. generok
    generok Well-Known Member
    2,350
    490
    Feb 7, 2013
    Anchorage, AK
    I tried running my 32" TV off of an old Radio Shack 150W inverter I had... It would power up, then down, up, down...
    I gave up on it but I pretty much think it is because it was a modified sine wave inverter. I might try again with a PSW inverter.
    I use the HDMI cable direct to HDMI on my TV now... it works GREAT! So SIMPLE. Plug it in to phone and either stream if we're in 4G service, or play downloaded video if we're not.
  11. erich82
    128
    59
    Mar 12, 2019
    I would bet more on the output capacity of your inverter. 150 watts isn't much for a TV (is that peak?). TVs in that size can range anywhere from 60 to 160 watts, more on the higher end if they are plasma. If you're planning on using a TV, I'd go with at least a 300W inverter.
  12. Orchid
    Orchid Sharp Shootin' Grandma
    4,852
    1,439
    May 8, 2011
    Florida by way of WV and MD
    We always camp with electric, so I'm going to have to figure this out. We have Direct TV, AT&T, Galaxy 8 phones, and a Firestick. We do have a 19" tv already in our camper, but it's an old piece of crap that came built in with our 2008 TT, so doesn't have HDMI port. We would have to upgrade to a cheap tv that has one.
    Thankfully, it doesn't usually rain very long here in Florida. We can play a quick game of Yahtzee and most rains will be over by then. Even so, may be nice to have cable in some situations. I'd rather have it available, and never use it, than need it for the grandchildren and not have to lose my mind keeping them busy in a pinch.
    Thanks for the idea, going to check the thrift stores for a suitable TV.
