Is there a way to stop bunk-end condensation?
Discussion in 'Cold Weather Camping' started by Camp-N-Nuts, Sep 9, 2012.
  1. Camp-N-Nuts
    Camp-N-Nuts KrustyKamper
    2,023
    Aug 9, 2011
    Central WI
    I was sleeping alone in one end and the temps were in the upper 40's...condensation formed on just my end. Both window ends were half-open...will a fan aimed at the tent ceiling help or is anything else advised? (curtains were open too)
    TIA! [;)]
  2. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
    I doubt you can ever stop all the bunk end canvas condensation, given certain atmospheric conditions and people BREATHING while the sleep ... (of course, you ask them to stop breathing while they sleep!)
    Covering the bunk ends goes a long way in helping, even with just a simple plastic tarp. I covered mine and sandwiched in-between a sheet of Reflectix and made night and day difference. Some of us started doing that even before the Popup End Cover Gizzmos came out, which is probably a better way to go.
    When the cooler outside air is one one side of the thin un-insulated canvas with warm moist air on the other side the result will be condensation dripping down on one's head! Here's a pic of a previous p'up with the plastic tarp cover (Reflectix underneath) that might give an idea of what I'm talking about ~
  3. billangiep
    billangiep Member
    290
    May 28, 2012
    Well short of holding your breath... [LOL]
    I would imagine the fan would help ?
    Also if your canvas has ever been cleaned with any type of bleach solution it leaves behind a type of crystal that absorbs moisture similar to salt. You can counter this by using hydrogen peroxide in a spray bottle, saturating the fabric, let sit for 20-30 minutes then wiping dry with a few micro fiber towels.
    After cleaning my canvas I had the same problem. I used about 32-40 oz. peroxide per bunk end....problem solved !!
    Bill,
    Myarch likes this.
  4. Camp-N-Nuts
    2,023
    Aug 9, 2011
    Central WI
    We had a heavy soaking in the evening and a cool night...so it was as damp as it gets! [{}=] I will try a fan tonight! [SNZ]
  5. kitphantom
    11,557
    741
    Adding Pop-up Gizmos helped a lot in our previous pup. We got them as soon as we bought the new Cobalt, so don't have a before/after to compare. For cold weather (30s and below), we got the bunk end liners, which were great when the temps hit the mid-teens to 20s. (There was frost between the layers when we broke camp after several days of rain, snow and those temps.) On that trip, we had power, so ran a space heater in addition to and instead of the furnace (we kept it in the 50s or so when we were in the pup); I'm sure that air circulation helped prevent condensation too.
  6. Unstable_Tripod
    14,279
    24
    May 20, 2008
    Seattle, Washington
    Since you (the OP) have already used slightly open windows and a fan for ventilation, I'd agree with the others that putting Pop-Up Gizmos on the bunk end roofs will make a huge difference. Using the Gizmos bunk end liners or putting Reflectix inserts in the windows will also help a lot, plus, these additions will help hold the heat in the PUP longer.
  7. Camp-N-Nuts
    2,023
    Aug 9, 2011
    Central WI
    We should have same temps tonight...I will try the fan tonight!
  8. daveo1289
    daveo1289 Active Member
    956
    62
    Apr 24, 2012
    Rochester NY
    You might want to try a small electric space heater to raise the temps in the camper. Warmer air will hold the moisture suspended it it until it can evaporate.
  9. Hawkester
    Hawkester Hawkesnest
    1,338
    26
    May 23, 2008
    SE Wisconsin
    Can't recall ever having condensation, we do camp alot in the lower 40's and 30's without heat. We have always left the bed end widows open along the top, the center (or highest windows) open at the top, and a fan. Never used Gizmos but I can see how they would help.
  10. BigBaron
    4,583
    Jun 21, 2012
    In tents we put a "roof" 3" over the tent. It usually stops the condensation.
    With our trailer we put a tarp over the entire trailer. Popup gizmos probably will do the same thing.
  11. Camp-N-Nuts
    2,023
    Aug 9, 2011
    Central WI
    I had condensation just the one time...after a lot of rain and a cool night. Now I have the roof vent open slightly and ceramic heater on very low at night. [8D]
  12. aslag
    aslag Pacific Northwest
    400
    Sep 8, 2008
    Pacific Northwest
    I forgot to attach our Gizmos one evening during a wet camping trip near the rain forest in the Olympic National Park. In the morning there was so much condensation it was nearly raining over the bunk ends. That was the last time I forgot to attach our Gizmos. We've had similar weather at the same campground with the Gizmos attached and there's been just minimal condensation not nearly enough to even drip.
  13. Ted S.
    Ted S. Member
    856
    Dec 20, 2011
    I agree with the heater recommendation. By raising the temprehature, you lower the relative humidity.
    Or, ventilate the moisture out. I am having a roof vent installed in the spring. I will run it at night on the cooler nights, when heat would be too much.
  14. infotech
    infotech New Member
    85
    Nov 4, 2012
    I don't know what part of this stopped the condensation, but I'll share what we did during our last trip to prepare for the cold and we didn't have any condensation for temperatures at night between 28 F to 50 F.. The temperature was between 50 and 70 in the popup depending on the temp outside.
    - put reflectix in every window on the popup (10 F difference in temp in front of reflectix and plain canvis)
    - two ceramic heaters pointed at the bunks
    - on our end of the popup I also put a 5x7 tarp on the outside of the bunk end
    - partially unzipped the windows on each end of the popup
    - partially unzipped a window in the middle of the popup
    We went back in November for a weekend that got down in the 40s and all I can say is the difference was night and day. We froze in November, condensation was dripping off the bunk end we were sleeping on. This time, it didn't even get damp.
  15. DenisD
    DenisD New Member
    Sep 10, 2008
    These are all great suggestions....thanks for all your advice. I also expernce this issue in early spring or late fall camping and will be sure to try some of these to hopefully extend the season a bit. :)
  16. Jazzygrl
    Jazzygrl New Member
    May 7, 2019
    Anybody ever try damp rid for moisture problems?
  17. Sjm9911
    3,642
    1,789
    Damp rid works great, but for condensation crack a panel and run a fan.
