Jack for replacing a flat tire
Discussion in 'Tires / Brakes / Bearings / Axles' started by sblanck, Nov 26, 2018.
  1. sleach
    661
    124
    May 17, 2014
    Boulder, Colorado
    When we towed with the Jeep liberty the tow unit jack worked fine. After switch to the Dakota pick 'em up that didn't work so well, so I went to an "automotive recycling center" and tried several scissor jacks. After finding one the right size- low enough to slip under spring perch with a totally flat tire- I used a disk grinder to do a bit of trimming to the top pad so it fit better. Stows in an outside access storage cubby with 12 x 12 piece of plywood and the two piece jack handle.
  2. gladecreekwy
    350
    335
    Sep 25, 2016
    23DA0452-6727-473A-8681-B9E79EC6A744.png Got this to jack my lifted TV. Very stable. Jack and stand combo.
    BillyMc likes this.
  3. Muller 5
    Muller 5 Active Member
    189
    33
    Jan 6, 2019
    STL
    Half the places I find this online, the description is of a crank jack. I can't afford the shipping from this seller and can only find it ship to store at Walmart with the wrong description. Has anyone else encountered this problem?
    Edit: This was supposed to quote the guy with the easy lift jack video. Obviously it didn't. The pics and description of the easy lift don't match on Walmart's website or on Amazon.
  4. PopUpSteve
    PopUpSteve Administrator
    17,732
    867
    Dec 22, 2002
    Malvern, PA
    You can find a decent jack at most any Auto Parts store. And Amazon has a good selection.
  5. xvz12
    xvz12 Well-Known Member
    664
    319
    Apr 6, 2017
    New Plymouth, ID
    I bought one of <THESE> on sale, & carry in my camping toolbag, works great. I can leave the handle off & chuck the other part in my cordless drill, & up the pup goes....lol
    nineoaks2004 likes this.
  6. nineoaks2004
    5,830
    2,078
    Graceville, Florida
    I carry a small floor jack from HF, ($29.95) and a piece of plywood for it to slide on, it works fast and easy.
  7. J Starsky
    J Starsky Well-Known Member
    542
    315
    Aug 3, 2017
    East Central MN
    I carry an smaller but older 2 ton and a full sized 4-way wrench that I use around the garage for smaller jobs. I trust that jack to lift the TT one axle, overkill for my pup.
  8. michaeltdyer
    michaeltdyer Member
    150
    Nov 26, 2012
    Denver Colorado
    I carry a small bottle jack, some wood blocks for spacers and a couple of jack stands. I tested everything in my yard to make sure I could change a tire, just in case.
  9. p
    p Active Member
    458
    81
    Jun 9, 2014
    Don't forget that the spare tiles nuts might be a different size then the nuts on the wheel.
    J Starsky likes this.
