Kojack Leveler
Discussion in 'Leveling Your Camper' started by BirdsNest, Jul 10, 2017.
  1. BirdsNest
    BirdsNest Active Member
    142
    32
    Jun 12, 2017
    Utah
    Anybody tried this one yet? http://www.campingworld.com/shopping/item/kojack-leveler/94165
    I found it while looking for a definite answer whether I can use the BAL on the big tires on my StarCraft 13RT. I was able to contact someone at Norco and they said that it might be possible to squeeze the BAL under the monster truck tires on my trailer, but it's very unlikely even after spreading the arms a bit...
    The Kojack looks pretty similar to the BAL, but is rated for up to 2200 pounds per wheel versus 1750 (I think) on the BAL, and purplelineusa.com (the manufacturer) says it takes tires up to 245/65R17 compared to the 13-15" inches supported by the BAL. That's a total tire diameter up to 29.54 inches and tire width of up to 9.64. The tires on my 13RT are 28.88 inches across and 9.25 inches wide, so that seems like a much better fit than the BAL. It does cost more, but it might have to become part of my future budget if its quality approaches that of the BAL.
    One thing I really like about the Kojack is that it has the ability to adjust the width built into the frame so it can be "custom fit" to the tire as long as the tire isn't too big or too small. The adjustable range doesn't look very wide, but it's nice to be able to snug it up (or loosen it a bit) to fit the tire properly.
    It looks like the potential weak point is the flexible joint at the top of the screw which adds convenience but also adds another potential failure point. Although if it's properly hardened steel, that shouldn't matter too much...
    edit: I just noticed that the Kojack also includes a carry/storage bag, which is super nice since that seems to be one of the biggest complaints about the BAL.
    ezakoske likes this.
  2. f5moab
    1,106
    262
    May 7, 2013
    Eastern Idaho
    Other than then being adjustable for a larger size tire and a swivel on top, a BAL is just as good and from the looks, the BAL looks heavier duty. I guess if I was in the market I would look at it, but my BAL is about five years old and has never failed.
    But yes, the BAL should include a storage bag. I guess many get the thermo pizza containers; I just fasten it to the front deck on my trailer for transportation.
  3. BirdsNest
    142
    32
    Jun 12, 2017
    Utah
    I would go for the BAL if I could since it's well known and tested, but I can't use it unless my tires go on a diet, so I'm seriously considering picking up the Kojack to try it out and hopefully be able to give it a thorough review.
  4. Sneezer
    Sneezer Active Member
    693
    146
    I have 13" tires on mine and the bal just fits. This looks to be a better solution for larger tires and it works better for duals as well.
  5. BirdsNest
    142
    32
    Jun 12, 2017
    Utah
    I guess I should have run out to buy one as soon as I made the original post here. They are now backordered and the person I talked to at Camping World didn't know when they might get more. So, my (hopefully) easy leveling days and a review of the product will have to wait for a while...
  6. f5moab
    1,106
    262
    May 7, 2013
    Eastern Idaho
    The BAL fits on my 15" tires, tight, but it fits.
  7. BirdsNest
    142
    32
    Jun 12, 2017
    Utah
    Do you happen to know the actual size numbers for the tires on your trailer? Mine are LT235/75 R15, so they are rather big at slightly under 29 inch diameter and 9 1/4 inch wide.
    The Kojack is larger than the BAL but it is still only rated for tires up to 29 1/2 diameter..
  8. Earthfairies
    Earthfairies Member
    40
    Jul 27, 2017
    Winnipeg, Manitoba
    Is there a minimum tire size on the BAL or the Kojack systems? I have 4.80 x 12" tires on mine.
  9. BirdsNest
    142
    32
    Jun 12, 2017
    Utah
    The BAL specs say that it works with most 13"-15" tires. I'm pretty sure I've seen reports of people using the BAL with 12" tires, but you might have to attach a board or something similar to the plates to make the surface area larger so it can hold on to the smaller 12" tire. The 12" tire is too small for the Kojack leveler.
  10. Earthfairies
    Earthfairies Member
    40
    Jul 27, 2017
    Winnipeg, Manitoba
    Thank you so much for the info. I will check into this further.
  11. arthuruscg
    arthuruscg Active Member
    1,367
    Nov 14, 2012
    I can use the ball leveler just fine with the 5.30x12 tires (currently using the Radial equivalent). If you had smaller circumference tires a then a board can be used to make the opening smaller.
  12. Earthfairies
    Earthfairies Member
    40
    Jul 27, 2017
    Winnipeg, Manitoba
    I did find that the 4.80 x 12 seems to be the same diameter as the 5.30 x 12 tires. I went to our local everything store called Princess Auto and measured the tires. I think I will order the BAL Leveler even if it needs a bit of adjusting for my tires as I feel it is very important to have the trailer perfectly level where ever possible.
    Thank you to everyone who has contributed and helped me out with my question.
