L.p. hose for outside
Discussion in 'Miscellaneous Repairs & Maintenance' started by Robandash, Feb 1, 2018.
  1. Robandash
    Robandash New Member
    Mar 11, 2016
    The camper is a 2004 Fleetwood bayside elite.the propane hook up that is outside on the very bottom of the camper in front of the wheel.directly above that is the stove that slides into the track.i need a new hose that connects the 2 due to a leak at the connector.not thinking I must have thrown away the old one instead of keeping it to order a new one and compare.anyone happen to know the hose I need? Colemanpopupparts.com has a bunch but different size and type connectors.thanks for the help
    Rob
  2. McFlyfi
    McFlyfi Active Member
    118
    26
    Aug 1, 2014
    That hose is for q quick connect setup (low pressure). 2004 Fleetwood probably had a high pressure setup (my 2004 Carmel did)
    OP- Is the port on the trailer threaded (threaded = high pressure)?
  3. lquinn1
    lquinn1 Member
    58
    Aug 17, 2017
    Champaign, IL
  4. Robandash
    Mar 11, 2016
    It is threaded so I'm gonna need the high pressure one looks like.forgot to subscribe to the thread so I didn't get the notification I had replies.thanks for the replies, tomorrow I'm gonna pull out the stove from from the pup and double check the hookup on it and then one on the pup to make sure the right size gets order.
  5. McFlyfi
    118
    26
    Aug 1, 2014
  6. Raycfe
    11,705
    48
    thats what you need .....^^^^^^^^
