LED's - New Bulbs or New Fixtures?
Discussion in 'Lighting, Interior and Exterior' started by Mamabear21, Mar 28, 2019.
  1. Mamabear21
    Mamabear21 New Member
    Mar 24, 2019
    I swear I searched for this topic and I either need more practice searching or it just hasn't been posted before. I am sure it's the former...
    Anyway, I would like to convert our lighting to LED and I am seeing that some just replace the bulbs with varying results and some get totally new fixtures. I realize that replacing fixtures is a bit more expensive but I want to do things right. Any suggestions would be greatly appreciated!
  2. Sjm9911
    2,611
    1,040
    Eaither way, 6 of 1 half dozen of the other. Im going to get bulbs. Eaisier.
  3. Dingit
    Dingit Active Member
    597
    208
    Mar 8, 2017
    I've done both. Super helpful, huh? :D
  4. fourhallatts
    fourhallatts Active Member
    807
    172
    Jul 18, 2015
    North Syracuse, New York
    We replaced our lights with LED lights that are battery operated. I have rechargeable batteries in them. They work great and turn on and off with a wireless switch. They are much brighter than what was originally in the pup. When my dh put them up they covered up where the old fixture was and you wouldn't know they weren't original.
  5. Matt Benoit
    Matt Benoit Active Member
    374
    201
    Jul 30, 2017
    Warren, MI
    Usually just replace the bulbs.. The new led fixtures sometimes have leds that aren't replaceable believe it or not. Just try to buy decent quality led bulbs. I've also learned that polarity is important! Good luck
  6. McFlyfi
    McFlyfi Active Member
    283
    98
    Aug 1, 2014
    Thousand Oaks CA
    I've just changed just the bulbs in both of my trailers. You can get expensive bulbs or cheap bulbs (Amazon), I've got a mixture of both, and have yet to see a performance difference. If there is nothing wrong with the fixture, it wll be cheaper and less labor intensive to just replace the bulbs.
  7. nineoaks2004
    6,234
    2,325
    Graceville, Florida
    I also just changed the bulbs in my TT. It was faster, cheaper and easier
    Good Luck and Happy camping
  8. Anthony Hitchings
    Anthony Hitchings Member
    87
    17
    Mar 2, 2019
    replaced with 5W bulbs (LED), but now moving up to 7W bulbs (LED)
  9. jmkay1
    4,027
    981
    I just replaced my bulbs. I bought some cheap knock offs from Amazon only to find they burned out the second I put them in. My dad suggested I try Auto zone and sure enough they had what I needed. Had them up for a whole season and glad I bought them. Way less battery usage and the lights much cooler to touch. My light fixtures were not broken and the plastic cover only slightly scuffed so felt I didn't need to go all out. Now if you have a certain scheme going on and was trying to beautify the camper, then go for it. No right or wrong way. I'm always of the mind, why fix what's not broke.
  10. xxxapache
    2,614
    660
    I bought cheap bulbs from eBay for about $1.50 each 4 years ago. If I recall correctly my TT has 18 bulbs. None have quit working.
  11. BikeNFish
    BikeNFish Well-Known Member
    2,172
    1,226
    Apr 24, 2017
    Maplewood, MN
    I just swapped out the bulbs.
    WingmanHG likes this.
  12. MNTCamper
    MNTCamper Active Member
    719
    102
    Jun 14, 2014
    I swapped the bulbs to SMD LEDs that I got on ebay. For $10 I got enough for the whole trailer and a couple of spares. I was happy with my existing fixtures. That was 4 years ago and it is all good. I like the flat SMDs for the applications like the ceiling lights, plenty of light.
  13. Mamabear21
    Mar 24, 2019
    Thank you so much for all of the responses! My initial thought was just getting the bulbs. Then I kept reading and found some articles/blogs where they replaced the fixtures with ones that had a switch that would allow for 1 or both lights to be on and had a dimmer as well. I was just wondering how well the LED bulbs would work in the existing fixtures. It sounds like it shouldn't be a problem. [:D]
  14. Snow
    9,511
    674
    Bulbs.. bought off Ebay and shipped from China..
  15. joet
    3,837
    606
    I replaced the fixtures, so I could control the light output. I have the old fixtures, if someone wants to pay shipping
  16. hotrodcamper
    hotrodcamper Member
    964
    Nov 3, 2012
    I bought LEDs last summer at a flea market,and am happy. Cheap,and light everything up very well. We normally don’t use the ceiling fixtures,but can now without having to worry about power consumption. Most of out lighting is with smaller portable LED lights.
  17. bobinfleet
    bobinfleet Active Member
    194
    62
    Sep 2, 2011
    Hampshire UK
    Same here, just changed the bulbs to led's
  18. darrenandmelissa
    darrenandmelissa Member
    299
    Jan 16, 2009
    Winnipeg, Manitoba
  19. neighbormike
    1,695
    893
    Oct 6, 2012
    WI
    I replaced the bulbs in my '14 and they worked great! Actually I have a bunch of 1156 style (and I think several others) left over if anyone around the Fox Valley - WI area wants them!
