License Plate light
Discussion in 'Wiring' started by mrjam2jab, Oct 9, 2018.
  1. mrjam2jab
    mrjam2jab Member
    82
    May 29, 2014
    1985 Sun Valley. How do you replace the light bulb?
    I thought the lamp cover would twist off. It did...but not the way I had hoped.
    Then entire socket on the left one is rusted out. Right one still seems solid....but still don't know how to replace the bulb.
  2. tombiasi
    4,750
    565
    You need to replace the entire assembly. The bulb just twists out or maybe pulls straight out..
  3. joet
    3,725
    567
    The bulb is replaced from the backside. Appears to be a 168 bulb
  4. emoney
    emoney Well-Known Member
    879
    441
    Jul 7, 2018
    Looks like it was designed for the dome to stay attached and the bulb to be removed from inside. On the bright side, you can now have new license plate lights! Yay?!
  5. theseus
    theseus Centerville, OH
    2,625
    291
    Feb 6, 2007
    Centerville, OH
    That's a standard assembly plate light. They used to be on the bumpers of 90% of trucks. An auto parts store will have them.
  6. Raycfe
    14,007
    951
    A light assemble like that was common to older pickup bumpers. They snap into the holes. Work great on nice strong metal bumpers, but not so much into fiberglass,etc.
  7. Sneezer
    1,322
    378
    I have a similar one as the entry/step light inside the door. On mine it just pops out completely, and then the bulb/socket assembly twists out from the rear. I also have the same on the bumper for my old truck, but it is easier to get to the backside without removing on it though.
    Might check the auto parts stores - they should sell the same type of light assembly in the trailer and/or lighting sections.
  8. mrjam2jab
    mrjam2jab Member
    82
    May 29, 2014
    There is no access from the back side. I guess they essentially pry out.
