Lift spring bent juuuust a little bit
Discussion in 'Lift Systems' started by MikeRule, Feb 12, 2018.
  1. MikeRule
    MikeRule Member
    35
    Nov 19, 2017
    South Shore, MA
    Howdy!
    Interested in opinions on the state of one of my lift springs. Certainly not the worst I could imagine, but I don't know what the tolerance of these systems is...
    As removed:
    After a visit to my favorite vice:
    Better, but there is still clearly a weak spot that might be a repeat bender. Replace, or save the $$ for the next surprise finding in this revamp?
    Thanks! Mike
  2. Antipodes
    Antipodes Call me Paul
    774
    74
    Jan 28, 2015
    Christchurch, New Zealand
    Yeah, I think you will get away with that.
    Turn it around so the kink is in the main tube, the good straight end feeds into your lift post. I think it will be just fine.
    Certainly worth giving it a go, nothing at all to lose at this point!
    BelchFire likes this.
  3. MikeRule
    MikeRule Member
    35
    Nov 19, 2017
    South Shore, MA
    OK, thank you for the input, I appreciate it.
  4. BelchFire
    1,623
    298
    Mar 29, 2012
    SE Georgia
    I agree; I would turn it around and not worry about it. Should be OK unless there's another problem that made it bend in the first place. If that's the case, you're just going to have to do this again. Any reason why it bent in the first place?
  5. f5moab
    1,438
    455
    May 7, 2013
    Somewhere in Idaho
    Would think it won't matter; however, why not just order a new spring? Can't be that expensive I wouldn't think. A double spring setup for a goshen lift are only about $60.
  6. MikeRule
    MikeRule Member
    35
    Nov 19, 2017
    South Shore, MA
    Oh, there might be a reason or two...
    So, this is how I purchased it - the PO wasn't great at troubleshooting. I'm actually surprised the spring wasn't worse. But everything around it is in tough shape. You can't see the bend in the track which is significant; the elbow and the lift spring suffered minor damage in this calamity.
  7. MikeRule
    MikeRule Member
    35
    Nov 19, 2017
    South Shore, MA
    Fair point, but given all the other parts this PUP needs just for the lift system, never mind the floor repairs in both the main cabin and popout, then a roof rebuild, I'm looking to save where I can.
