Lifting a Coleman
Discussion in 'Taking Your Camper Off Road' started by roughin-it, Oct 27, 2010.
  1. roughin-it
    roughin-it New Member
    143
    Oct 20, 2010
    So I'm just trying to gather some info on ways to lift my Coleman Yuma and so far the easiest way is to use the Dexter Axle spring relocation kit for around $50. It relocates the leaf springs from being mounted on the under side of the axle to being mounted on top. Seems like a decent option. I wanted to share a great image I found of the under side of a Coleman E3 which some of you may know comes lifted stock. You can see that it looks pretty simple with just having spacer blocks between the leaf springs and the frame. The E3 does have the added bonus of having the shocks and the swivel pieces so the spring and pivot while it flexes.
  2. plug ugly
    plug ugly New Member
    38
    Aug 17, 2010
    from a parts cost and fab point, its easiest to do like you said and put the springs on top of the axle tube.
  3. Dusty82
    Dusty82 Active Member
    3,513
    Jun 23, 2008
    Northern Nevada
    Some other models of Coleman/Fleetwood trailers may come the same way as that E3. Our '75 Coleman Patriot came from the factory with the axle mounted under the springs like the picture above. There are no provisions for shock absorbers, but I'm contemplating that - along with how much lift I really want. Personally, I'd take a look under your pup to see what you need before ordering anything.
    Just a quick pointer here: On a recent trip to NAPA, I was browsing in the trailer aisle and found spring perches for solid and tubular axles in various sizes. The most expensive perch was around $6. All it would take would be measuring the diameter of your axle and buying the right spring perch - of course you'll need new U-bolts too and they had them as well - around $3 each. If you're considering a flip, this may be a less expensive option for you.
  4. mdigby
    mdigby New Member
    279
    Sep 9, 2007
    In addition to the "axle flip" kit, Many Colemans have two spring mounting holes on the frame.
    It MAY be possible to gain SOME altitude without either the blocks or the flip kit. Take a look.
    Good luck
  5. mdigby
    mdigby New Member
    279
    Sep 9, 2007
    Here is a picture of the mounting holes I am describing.
  6. cico7
    cico7 Friend request denied.
    206
    Jun 21, 2011
    Any more pics of your lift???
  7. roughin-it
    143
    Oct 20, 2010
    We actually ended up trading in for an evolution to save the pain. It was going to take the following:
    new axle/spring mounts
    bigger wheels
    bigger tires
    new corner stabalizers x4 (or bring blocks with us everywhere)
    a new front crank for de-hitching.
    a way to add a step at the entry way
    I realize some of that stuff we could get by without but we wanted a reliable off roader.
  8. roughin-it
    143
    Oct 20, 2010
  9. Peters Dad
    Peters Dad New Member
    Dec 4, 2015
    2002 Coleman Sun Valley- Here's my homemade (no kit) axel flip result from a few years ago. Essentially I put the springs above the axel, that's about it. Make sure the bend of the axel is up- used the stock 2700lb. axel. I gained about 4.5" in height and spent maybe $15. Double nutted (w/nyloc nut) the U-bolt just for security. Here are some photos- better than I can explain it (don't ask me to! Laugh). First photo close-up. Second photo in campground- hard to see actual lift without comparison. Third photo, 15 miles off the paved road at 5400' elevation. Caught in a storm- lost the awning to wind then got three inches of snow unexpectedly. Water line almost froze, knocked snow off the canvas every couple of hours. I don't recommend camping in the snow but the trailer otherwise performed quite nicely.
    Modify message
  10. dbhost
    dbhost Active Member
    528
    199
    Sep 19, 2018
    League City, Texas USA.
    LOL. I have had on 2 different occasions, once in 1993, and the last time in 2004, I have been camping in the mountains, in the summer, and ended up being snowed on in July. It was really an eye opener...
    I've never seen snow build up on a pop up in use like that... The snow typically melts off the bunk ends before it can build up.... Must have gotten nasty cold where you were!
  11. dbhost
    528
    199
    Sep 19, 2018
    Been looking into these to get a 1996 Coleman Santa Fe out of the sand, and to keep from dragging the back of the trailer to hunting camp.
    I saw a guy on Youtube that did an SOA on a Coleman Yukon I think it was, while swapping in a heavier axle as his original was bent. Not a bad idea as the OEM axles typically aren't rated to allow any real payload in the trailer like silly things such as food, water, fuel etc...
    Anyway he used a larger tube axle, along with a taller axle perch, which meant that his SOA netted him I believe 7" and got the tires out of the wheelwells, which allowed for a wider footprint tire, good for sand / beaches...
    I think for me at least, I would work with my tire guys to get appropriately wide wheels and tires with a proper load rating that would allow me some decent floation over sandy terrain. Not looking to gain lift via tires, looking for lift from the SOA, and flotation from the tires.
    After that, swap out, if need be and I suspect it will, the stabilizer and leveling jacks with ones with longer reach.
    And since I will be frequenting the beach, apply copious amounts of lube to the jacks... And frequently inspect for, and treat any rust...
  12. WVhillbilly
    WVhillbilly Well-Known Member
    527
    358
    Jun 6, 2018
    WV
    You'll need bigger tires just to fill up the space under the newly lifted camper.
    But you'll gain quite a few inched that way, not to mention you'll have room for wider tires which will help with flotation.
    Try to find a dry lube (teflon) for your jacks so that sand doesn't stick to the threads.
    We found blocks to put under our jacks, as our camper sits tall from the factory and the jacks just barely reached the ground.
    They were fairly cheap and stack together so they don't take up much room.
