Looking for a pop up camper for family of EIGHT
Discussion in 'Introduce Yourself' started by ThatKevin, Mar 14, 2019 at 8:13 PM.
  1. ThatKevin
    ThatKevin New Member
    Thursday
    Miami, FL
    Any suggestion on what used pop up camper to look for? Budget is up to 10K
  2. Sjm9911
    2,327
    886
    That will be tight! Ages? Pop up and a tent or 2?
    neighbormike likes this.
  3. BikeNFish
    BikeNFish Well-Known Member
    2,014
    1,138
    Apr 24, 2017
    Maplewood, MN
    Wow, that's a tall order to get eight into a pup, but not impossible. I would suggest a high wall pup with a slide out. A $10K budget might also get you there. I would also suggest that as the kids get older, buy a small tent to set up next to the pup. And don't plan on everyone eating around the table inside the pup.
    My pup has this layout:
    Technically it can sleep eight when you convert the dining areas into beds. It is not a high wall.
  4. neighbormike
    1,575
    805
    Oct 6, 2012
    WI
    Welcome from Wisconsin! I agree with both of the above!
  5. WrkrBee
    WrkrBee Well-Known Member
    1,166
    410
    Welcome to the Portal from South Carolina.
  6. PopUpSteve
    PopUpSteve Administrator
    17,821
    922
    Dec 22, 2002
    Malvern, PA
    Welcome to the PopUpPortal
  7. CamperChrissy
    CamperChrissy Active Member
    456
    182
    Nov 25, 2016
    Chicago suburbs
    We have a 2006 Niagara HW that has kings on both ends. We comfortably sleep an adult, a teen, and a small kid in a king. So if at least some of the kids are small, that could work. Keep in mind that a dinette that turns in to a bed is usually shorter than a normal bed. Best for kids up to maybe age 10 or 11. Some models have a dinette and a sofa bed. You will definitely need a big PUP! Good news is that $10k is a very healthy budget for a large used PUP.
    Here's something I found in a quick search that might fit the bill (just an example, of course too far from you!):
    https://www.rvtrader.com/listing/2016-Forest-River-Rv-Rockwood-Premier-2317G-5004776794
  8. Sjm9911
    2,327
    886
    My westlake is similler, but no slide out dinette. Its big for a pop up, 8 people in it, i wouldn't do it unless small kids, and a outdoor area, so maybe add a room . Plus a tent for middleage kids and a pop up room. My pop up screen room can fit 8 easy for eating. Next is the outdoor cooking set up, as there will be no room in the pup. Its possable, just need to think ouside the pup!
  9. jmkay1
    3,905
    909
    A large camper with a slide out may be your best option. I have Fleetwood Utah which has two king beds, a dinette table that turns into a bed and the couch folds down into a bed. If two of your kids are small enough they could fit on the table bed. The couch is really only big enough for 1 so if you can fit three kids on the king bed that leaves the other bed the the other 2. The larger campers have a gross weight of over 3600 or more so you will have to have a large enough vehicle to tow it. Also keep in mind that you have to go by your vehicles payload numbers as well as tow rating and keep in mind your passengers count as payload.
    Buckmaster81 and Sjm9911 like this.
  10. jmkay1
    3,905
    909
    mod5693.jpg a picture of my floor plan. I personally like this floor plan better as people have walking space and people can eat at the couch and still be together.
    MrsSquid likes this.
  11. Muller 5
    Muller 5 Active Member
    219
    40
    Jan 6, 2019
    STL
    Hello from St Louis
  12. kcsa75
    kcsa75 Well-Known Member
    1,987
    775
    Sep 9, 2013
    Kansas City
    Greetings! Welcome to the forum from Midway USA.
    Good luck on your search. With a little creativity and patience you'll find something that works for you.
  13. GreyFox
    GreyFox Active Member
    415
    148
    Oct 10, 2018
    S Ontario
    8 people in one vehicle while also towing a trailer is a tall order so what are you intending to tow with? [?:~{]
  14. PopUpSteve
    17,821
    922
    Dec 22, 2002
    Malvern, PA
    Here's one. Only used once.
  15. Sjm9911
    2,327
    886
    Omg , forgot about that one!
    jmkay1 likes this.
  16. nineoaks2004
    5,983
    2,194
    Graceville, Florida
    Welcome from N/W Fl panhandle good luck in the search and happy camping
  17. neighbormike
    1,575
    805
    Oct 6, 2012
    WI
    Great BB episode! That camper really took a beating when "Mr. Howel" towed it into town while still setup! [LOL]
  18. arge
    arge Member
    37
    Feb 27, 2018
    I suggest renting one first or having some sort of advanced "training". Although it is not impossible and it can be done (considering 4-6 kids + adults), keep in mind that basically, all of you are going to sleep in the very same room and the room is quite small. It will be very cozy. I guess you know that.
    Anyway, if you have a chance to borrow a large unit or to rent one, I will suggest to give it a try first. At worst, just get together at home and try to spend a night+ breakfast in 150sqft room.
    As many suggested, you must have at the camper an extra tent, add a room etc. you must move the center of activities outside, able to stay there and have a roof, gazebo etc.
    Also, not sure about your camping history, but given the number of the participants, I would take a look into tents. For a fraction of the cost of a popup, you can go for very good quality tents able to accommodate your needs. We are talking here about big tents, with multiple rooms etc. Go for the good ones. Match this with good self-inflatable mattresses (thermarest type), good sleeping bags and you get a winning combination.
    Get the cheap tents, the $20 air mattress and the $25 sleeping bag and you are going to have a bad experience.
    You can go for one or two tents (keep in mind that some campgrounds limits the nr of ppl to 6, though I guess you may get a break giving the fact it is a single family)
  19. Shaman1
    Shaman1 Well-Known Member
    1,470
    193
    May 13, 2011
    Oklahoma City, Oklahoma
    Welcome from Oklahoma. Good luck in your search.
  20. Raycfe
    14,002
    948
    Greetings from the Connecticut shoreline.
