Loud Clunk When Lifting Roof
Discussion in 'Lift Systems' started by Garrity, Mar 7, 2019.
  1. Garrity
    Garrity Member
    51
    Feb 6, 2018
    Arizona
    Lately when lifting my roof, I am hearing 2 loud clunks when doing so. After some research here, I found some folks that had a similar issue/sound. It seems the spool(not sure if this is the actual term) on the front of the camper is keeping the lift cable all on the left (driver) side of it. It then gets to the top and is forced over to the base of the spool, making the loud noise. I don't see a way to adjust mine though, that other threads mentioned. Any ideas? Could this cause damage to my lift system? Goshen lift system on a 2005 Starcraft 3606.
    Thanks,
    Patrick
  2. gladecreekwy
    379
    353
    Sep 25, 2016
    Mine does that as well. I took the cover off the winch and watched it. It’s the cable slipping as it winds and readjusting itself. If you can get a look at your spool check it out.
    Grousetales and Sjm9911 like this.
  3. BikeNFish
    BikeNFish Well-Known Member
    2,014
    1,138
    Apr 24, 2017
    Maplewood, MN
    It's pretty common. Mine does the same every time I raise the roof and I never get used to it. It always makes me raise an eyebrow.
  4. Garrity
    Garrity Member
    51
    Feb 6, 2018
    Arizona
    My feelings exactly.
  5. generok
    generok Well-Known Member
    2,276
    413
    Feb 7, 2013
    Anchorage, AK
    Mine did it every time I raised it at crank 27. Everyone counts the number of cranks, right? I'm not the only crazy one?
    Garrity likes this.
  6. GreyFox
    GreyFox Active Member
    415
    148
    Oct 10, 2018
    S Ontario
    Most popup lift systems are essentially a winch where a main cable wraps around a drum. Once the first layer is complete the second layer starts to wrap, atop the first layer, but sometimes the cable catches the edge of an adjacent wrap and slips, thus causing this clunking noise. The Coleman / Fleetwood lift system doesn't suffer this issue because there is no cable wrapping - instead the wiffle tree to which four separate lift cables are attached travels along a threaded drive screw.
  7. kcsa75
    kcsa75 Well-Known Member
    1,987
    775
    Sep 9, 2013
    Kansas City
    According to a tech at the local Jayco dealer, that's supposed to happen. I didn't ask why. [:)C]
  8. Garrity
    Garrity Member
    51
    Feb 6, 2018
    Arizona
    Thanks everyone for the replies. This puts me a bit more at ease knowing it is fairly common.
  9. Grandpa Don
    Grandpa Don Member
    97
    40
    Sep 5, 2018
    Yep...I have the same "clunk/snap" sound every time I raise my top. The only problem with it that I have found is that the wrap actually changes the draw length of the cable. Which in turn might not let the top go all the way up. The winch will hit the upper limit switch and the top will stop about 3 inches from the full up position. On mine it is easy to adjust the switch. I just lay down on my back under the tongue, that's where my winch is mounted, and reach up and adjust the switch. After I had a new lift cable installed I had to make the adjustment several times due to new cable stretching.
