Low point drain
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by handdydaddy, May 9, 2019.
  1. handdydaddy
    handdydaddy Active Member
    112
    34
    Jun 28, 2013
    I have a 2016 Jayco 10sd. I have water in my fresh water tank, but can’t figire out how to empty it. I went to the area that says low point drain and there are no valves. I unscrewed the plywood covering the bench holding the tank and there was one valve that appeared to lead to the exterior. Turned it with no luck. I looked to see if the hole was clogged and it doesn’t appear so. Help!!
  2. PopUpSteve
    PopUpSteve Administrator
    18,176
    1,130
    Dec 22, 2002
    Malvern, PA
    Is there a bolt on the bottom of the water tank, like an oil pan on a car engine?
  3. roybraddy
    roybraddy Well-Known Member
    1,937
    584
    Mar 23, 2016
    King George, Virginia
    Interesting no drain valve there...
    My Off-Road POPUP has the fresh water tank and the shower drain both coming to a very visible valve. You can see it here under the fridge vents in this photo showing how I drain my sink when camping off grid haha...
    Roy's image
    Roy Ken
  4. kcsa75
    kcsa75 Well-Known Member
    2,290
    939
    Sep 9, 2013
    Kansas City
    Our Jayco Eagle doesn't have a drain valve on the fresh water tank. When we sanitize it, we just run the faucet until it's empty.
  5. WrkrBee
    WrkrBee Well-Known Member
    1,524
    538
    That's where the user has to use a drill to drain the tank and install a valve. It's too complicated for the manufacturer to figure out how to install a fitting, hose, and valve. That's weight and money they do not want counted.
    neighbormike likes this.
  6. handdydaddy
    112
    34
    Jun 28, 2013
    I emailed Jayco to see what I was doing wrong. I sent them a picture of the bench storage area and the valve that I suspected was correct. They confirmed I was right. I have turned it and still no draining. I’m going to see if I can find something of the appropriate size to try and snake the tube with. Hopefully a muddobber built a nest in there or something of the like and I can clear it out and make things work.
