Lug nut size on my PUP
Discussion in 'Tires / Brakes / Bearings / Axles' started by PopUpLarge, Jul 11, 2018.
  1. PopUpLarge
    PopUpLarge New Member
    28
    Jul 10, 2018
    The camper I just got (1991 Viking 180) has larger than what I consider "normal" nuts on the lugs. They're either 13/16 or 15/16 instead of the 3/4 nuts I'm used to. Also, they're standard nuts, not actual lug nuts, so the threads of the lugs are exposed. Can I just use standard sized lug nuts? I have a bunch from my Jeep and they will thread on to the lugs.
  2. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    The ones on the pup are probably not correct.
  3. PopUpLarge
    28
    Jul 10, 2018
    That's what I'm guessing. This was clearly fixed up a bunch of years ago. You think I can swap standard automotive 3/4th lugnuts? I can't imagine why not as long as they get proper torque.
  4. joet
    4,256
    756
    AS long as the seats match the wheel and thread size is the same, you can swap
  5. Raycfe
    14,534
    1,120
    Ditto watch the seats maybe different between mag and steel rims. Clean the threads and a "little anti seize" maybe a good idea. Cleaning the treads on the nut and stud is important because if the stud goes into dirty/rusty part of the lug nut in could not tighten completely or even break the stud.
