"Must Haves" for the first time PUP owner
Discussion in 'First Time & New Camper Owners' started by DelorFamily, Aug 7, 2008.
  1. Alan
    Alan Active Member
    450
    89
    Mar 18, 2017
    Reno, NV
    Call a locksmith and they can come out and make a key or take it to a lock smith.
    stacey short likes this.
  2. kitphantom
    11,361
    583
    Depends on the age and brand of your pup, and whether or not a previous owner has replaced the locks. Many use the same keys, so you may be able to buy a key from a dealer. Or, if you can remove the lock, you can take it to a locksmith or dealer and buy a replacement of the same type - that's what we did for the storage area locks on the TT. We didn't like the idea that lots of folks had the key to our storage areas. We've also replaced the door handle/lock on the TT, because something broke in it.
    We never worried about having keys on our first pup, we never had them (we were the 3rd owners). It is, after all, easy to just open the canvas and get into the camper. We did lock the door from the inside sometimes, sitting on the bench next to the door would push the latch and the door would swing open.
    Second pup really needed the the lock on the half (outer) door locked to keep it shut on the road.
  3. SteveP
    SteveP Well-Known Member
    1,153
    240
  4. PaThacker
    PaThacker Well-Known Member
    1,162
    96
    Feb 11, 2010
    Poconos
    Must haves for first time pup owner: at minimum pup should have a refrigerator, 26 gallon water capacity, hot water heater, outside shower, boxed frame and one piece roof.
    From that point you have a decent starting point. Add popup gizmos, fantastic fan, mattress covers, porta pottie, and privy shelter.
    The rest comes from experience and usage types. Off grid go 12 volt and cast iron. Campground go micro fridge and slow cookers or this foodi do it all cookers.
  5. stacey short
    stacey short Member
    107
    19
    Jan 5, 2019
    No heat or air and no hot showers. It does have a sink and stove top and a stove to cook outside. I do have a air conditioning to add and a heater it did come with a refrigerator but I'm not sure if it works. I haven't plug my camper up yet. I do have a refrigerator to put in it. I'm going to look under the sink to see if I see a hot water heater but I doubt it.
  6. CamperKaren
    CamperKaren New Member
    Saturday
    We’ve been on one outing now and learned we must get a water filter. First time hooking up to water and it was nasty!
    Toedtoes likes this.
  7. Toedtoes
    Toedtoes Well-Known Member
    1,089
    669
    May 28, 2018
    An RV extension cord is an extension cord of the same amperage as your camper.
    I your camper is a 50amp system, then get a 50amp extension cord. If your camper is a 30amp system, then get a 30amp extension cord. It will give you a longer reach when needed at the same amperage as your system and the cord will be rated to handle that amperage.
  8. Toedtoes
    1,089
    669
    May 28, 2018
    I find must have lists to include a lot of individually debatable items.
    Whether I have power or not, I never use slow cookers, microwaves, or other electric appliances. My exception will be a toaster oven in the FoldnRoll because it doesn't have an oven built in.
    Generators, solar, etc., are also things I don't bother with even though I'm usually dry camping. My battery will last over the week. I have lithium jump starters that can charge cell phones and kindles, etc.
    I do carry two 20ton bottle Jacks and a portable air compressor as well.
    To me, must haves are more about safety and survival than convenience. Tools, first aid, emergency food (a few canned items that can be eaten without heating if needed), etc.
    Everything else is dependent on how you use your camper and your personal desires.
    WingmanHG likes this.
  9. Jess n JJ Julian
    Jess n JJ Julian Member
    52
    19
    Jul 26, 2017
    TX
    Small metal clamps. If a cable, or any part of the cable breaks, one corner of your pup will not be able to lift and your trip will be doomed. The clamps will save the day! You will need a couple of strong arms to lift the corner while someone cranks up the top. As the poles extend, you place clamps at each point where one post slides into the other and it will prevent it from collapsing. This will hold it until you can fix it. Our camper needed two clamps for this to work. It saved our holiday! pic is an example. 15552898510876039662934859970225.jpg
    J Starsky and eoleson1 like this.
  10. Runawayhome
    Runawayhome New Member
    Feb 11, 2019
    Cleveland, Ohio
    Thank you so much! This post has been a great help!
