Need some help
Discussion in 'Mystery Parts' started by v1ru5879, Aug 6, 2018.
  1. v1ru5879
    v1ru5879 New Member
    23
    Aug 2, 2018
    Just have a few pictures I thought I would post and find out some info. First is the c channel for and awning, looks like two small pieces were added. Or is this factory? Also I'm assuming these are for the awning supports? Mystery switch on the light, couldn't see it operating anything while messing with it. 20180806_201627.jpg 20180806_201408.jpg 20180806_201359.jpg 20180806_201617.jpg 20180806_201520.jpg
  2. Sjm9911
    1,984
    792
    Added , for a bigger awning or to repair damage.
    kitphantom likes this.
  3. neighbormike
    1,427
    728
    Oct 6, 2012
    WI
    I agree, a PO probably extended the rail to add a bigger awning... that switch should turn on/ off your porch light... if it does nothing, check the bulb 1st.
    nineoaks2004, jnc and J Starsky like this.
  4. v1ru5879
    v1ru5879 New Member
    23
    Aug 2, 2018
    Where would said porch light be located? I guess I should mess with it while it is dark out to see if anything lights up
  5. emoney
    emoney Well-Known Member
    879
    436
    Jul 7, 2018
    I think they are saying the light it’s under is the porch light. They use amber covers to help prevent bugs
    kitphantom and jnc like this.
  6. Rusty2192
    Rusty2192 Active Member
    669
    192
    Jul 30, 2014
    Kentucky
    The bracket in the 4th picture is for a Carefree of Colorado awning. Like the others said, the switch should operate the light that it’s mounted to.
  7. myride
    myride Well-Known Member
    749
    320
    May 14, 2015
    Edmonton, AB
    Agree with all of the above.....
