no washer between castle nut and outer bearing
Discussion in 'Tires / Brakes / Bearings / Axles' started by SpecialGreen, Jul 10, 2019.
  1. SpecialGreen
    SpecialGreen New Member
    29
    Jul 5, 2018
    I am looking into my pup's bearings for the first time. I have a 2002 Coleman SantaFe 10-foot with 7" e-brakes. The inner seal appears to be about 1.5" ID, 2.05" OD; the spindle is 1". According to ColemanPopUpParts, Coleman used a 1" spindle with 2"OD seal and 7" brakes on its smallest pups, and nothing else on the pup has been replaced, so I think it's the stock axle.
    When I pulled-off the castle nut, I did not find any washer between the castlenut and the outer bearing. My first thought was that there is always either a D-washer or a washer with a metal tab that fits into a cutout groove on the spindle. But, looking at my spindle, it is clean threading with just the hole for the cotter pin. There is no cutout/groove, so a plain washer with 1" ID would fit, but a D-washer would not fit. So, as I think about it, I'm not sure what a plain washer would really accomplish: it would rotate freely around the axle. Maybe there is supposed to be no washer under this castle nut?
  2. rabird
    6,554
    248
    TX
  3. joet
    4,272
    770
    This is common for a lot of smaller axles. Put it back together and don't worry
    Rusty2192 likes this.
  4. Raycfe
    14,577
    1,146
    What Joet said ^^^^^^^^
  5. SpecialGreen
    29
    Jul 5, 2018
    ...or maybe worry. Plenty of grease. Outer bearing red, inner bearing muddy. looks like some material ground off the inside of the outer bearing:
    https://tinyurl.com/y4ctmrcf
    There's some discoloration on the underside of the spindle. Races look good. inner bearing spindles are toasty tan, but not pitted. All in all, I think they deserve to be replaced. I will put some Honda Moly 60 or moly CV grease on the spindle.
    FYI, my 2002 Coleman SantaFe 10' has bearings which I measure at 1.059" ID (probably L44649 1.063") and seals I measure at 1.5" ID. That looks like a match to this $12+s&h kit:
    https://www.etrailer.com/Trailer-Bearings-Races-Seals-Caps/etrailer/BK1-150.html
    (no idea if those bearings are good... but the ones I pulled out have no markings at all!)
    When I look at the Coleman parts manual, I see a bearing kit for 7" brakes with p/n 4716-1101. According to http://www.popupportal.com/threads/replacement-bearings-in-coleman-fleetwood-shenandoah.64708/ , that would include:
    - L44649 bearing (1.063" ID, yes)
    - 13194TB seal (1.37" ID, doesn't match my spindle)
  6. joet
    4,272
    770
    Am not familiar with the Honda greases but any quality grease with a NGIL 2 rating and a drop point of at least 450 degrees or better is what's needed
