No z amp outlet?
Discussion in 'Camping Green' started by Popupdoc, May 1, 2018.
  1. Popupdoc
    Popupdoc New Member
    May 1, 2018
    Hi all. Just bought a 3016 Rockwood freedom 2318g popup. It has a zamp ready sticker but I cannot find the outlet at all. Anyone else have this problem.
    I also just bought a Coleman 100w solar panel and charge controller from Costco. Anyone have any experience with it?
    Thanks
  2. kcsa75
    kcsa75 Well-Known Member
    1,096
    270
    Sep 9, 2013
    Kansas City
    I had to Google Zamp to know what you're talking about, so I'm not going to be much help, but wanted to be the first to welcome you to the forum. [:)C]
  3. bearman512
    bearman512 Well-Known Member
    1,173
    36
    Apr 17, 2010
    Albuquerque NM
    Look for a black port around the lower portion of the trailer. If not there then look on the roof. Here is a picture of the port. By the way Zamp is reversed polarity and you will need to change or reverse the black and red wire from the Solar Panel for it to work with the Coleman.
  4. BikeNFish
    BikeNFish Well-Known Member
    996
    549
    Apr 24, 2017
    Maplewood, MN
    Hello and welcome from Minnesota. I wish I had a solar ready pup.
  5. kitphantom
    10,721
    307
    If it is used, maybe the original owner removed it. Work back from the battery area and see if you can find the wiring. I would assume that the outlet was there somewhere if it was classified as "Zamp ready"; if the wring was there but not the plug, you'd think it would be "almost ready"
    Courtenay installed a Zamp outlet on our Retro, since they weren't yet standard when we bought it. At the time, 3 years ago, Zamp seemed to be the best choice for up-sizing our solar set-up. (Our previous one was Goal Zero, on the pup.) We haven't regretted it.
  6. CamperJeff
    CamperJeff New Member
    Apr 30, 2018
    Western Massachusetts
    My Zamp plug is on the front frame rail of the camper, between the "A" arms that form the tongue. It's just a small black plug like in the photo above. It's not labeled and hard to find if you don't know what to look for. Hope this helps!
