outlets not working - lights and ac ok
Discussion in 'Miscellaneous Repairs & Maintenance' started by kansas_family, Mar 8, 2009.
  1. kcsa75
    kcsa75 Well-Known Member
    2,110
    843
    Sep 9, 2013
    Kansas City
    Are you plugged into shore power or running off the battery? If it's the latter, you only have 12v power and the outlets will not work.
  2. Jessesilva81
    Jessesilva81 New Member
    Sunday
    I am running just off the battery..so then there no way my outlets are going to work?
  3. kcsa75
    2,110
    843
    Sep 9, 2013
    Kansas City
    Correct.
  4. kitphantom
    11,361
    583
    No, outlets will not work unless plugged into shore power (or generator, or using an inverter if you have a large enough battery bank). Think of your 110 outlets as the end of a strange extension cord - for there to be power at the outlet end, you must be connected to power at the plug end.
  5. roybraddy
    roybraddy Well-Known Member
    1,850
    523
    Mar 23, 2016
    King George, Virginia
    Here is a typical 30A setup block diagram... Sometimes it is nice to see all in a pictorial...
    Roy Ken
