Painting your PUP
Discussion in 'Miscellaneous Repairs & Maintenance' started by bobcap, May 14, 2008.
  1. bobcap
    bobcap New Member
    Feb 15, 2008
    Hey all;
    I've seen quite a few posts concerning painting your PUP's. As soon as I replace my lift cables this weekend, Painting the Interior,Exterior & frame is next up on my extensive list.
    Can you please let me know the best method of achieving a good result?
    (I.e - paints, primers etc...)
    The exterior is aluminum, the roof is severely pock-marked from hail damage (but not leaking) - Would Kool Cote work for this?
    I am also going to replace the decals with something custom, so looking for ideas for that as well
    Any suggestions, hints, gotcha's are welcome
    Thanks up front
    bob
  2. newbiecamper
    newbiecamper New Member
    258
    Apr 7, 2007
    SE Minnesota
    check with a local paint store or body shop on the proper type of paint to use on aluminum. I paint with enamel at work, on steel. I think a good scuff( i recomend scotch-brite pad) to the existing paint is important, then a good primer.make sure you mask off all the lights and fixtures, or remove them. maybe even mask a 'skirt' around the pup to avoid overspray on the wheels and frame, unless you are going to brush it on. and remember to take lots of pictures, before and after so all can see your painting mod.
    http://community.webshots.com/user/newbiecamper
    Me `71 - DW `73 - DS `88 - DD `91 - DS `96 - DS `00 - DD `03 - Buddy the Beagle
    `91 Jayco 1006 deluxe
    `98 Ranger
    Nights camped in 2007= 11
  3. Big_kid
    Big_kid Virginia Beach, VA
    2,208
    Jan 13, 2008
    I just painted the aluminum roof on our pu with the RV roof paint from walmart. The can said to do the seam, then the first coat lengthwise, then the second coat crossways. It took about 3/4 of the gallon can. I read on here somewhere that someone had it tinted to match, and it came out nice. YMMV.
    Welcome to the portal!
    Me 66
    DW I value my life
    DD 96
    DD 00
    DS 03
    Starmaster 8 68
    Mercury Villager 95
  4. christate1970
    christate1970 Member
    266
    Sep 9, 2006
    If the exterior aluminum is already painted all that need to be done is scuff it. The existing paint is like a primer and it is bonded well to the aluminum. If you sand all the paint off and have bare aluminum you will need soome type of etching primer. One etched you can use any paint.
    2005 Kia Sorento
    1980 Coleman
  5. jwolfe01
    jwolfe01 Honeoye, NY
    779
    May 5, 2008
    Honeoye Falls, NY
    You can use pretty much any paint that you want to, its up to you. The biggest difference in paints is how many steps you want to go through. There is single stage paint, which is very easy, then you have 2 stage where you spray a base coat and then a clear coat, which holds up and looks deeper than single stage, and then you can even get into 3 stage paint for pearls or candy colors. I will be doing a custom graphics job on mine, and will be using a 2 stage paint so that I can lay on a base coat, then paint the graphics on and then lay on some clear over everything.
    Before you paint, you will need to scuff the existing paint with scotch brite or a fine grit sand paper and then thoroughly degrease the surface, then clean it with some thinner to remove any dust, etc. Make sure that you tape anything off that you dont want paint on, or just remove it. Definitely tape and skirt off the bottom of the PUP, nothing looks worse than overspray. Take your time and make sure that the paint does not dry too quickly or you will get "tiger striping" from where you overlap your passes.
    A good site to see the complete details on what the differences are in what types of paint is www.ppg.com
    Good Luck!
    _________________________________________
    TV - 98 Jeep Cherokee Classic <img src=../Images/icons/icon_smile_jeep.gif border=0 align=middle alt="Jeep">
    PUP - 89 Starcraft Nova <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp">
    Lima NY
  6. christate1970
    266
    Sep 9, 2006
    Good advise jwolfe01. You must be in the paint trade. I used PPg Delfleet Single Stage urethane for the white and I used basecoat/clearcoat for the band stripe. I have pics on my webshots. If you are going to use Single Stages check out some industrial Single Stage Urethanes. You can almost get the same look as a automotive paint but at a fraction of the cost. You can easily spend $300 on materials to paint your pop up. The nice thing about the industrial urethanes is if you dont reduce them you can get a nice textured finish for the roof of your PU.
    2005 Kia Sorento
    1980 Coleman
  7. jwolfe01
    779
    May 5, 2008
    Honeoye Falls, NY
    Well, I worked in a body shop for a few years, and am a very avid car guy. Ive painted my fair share of cars lol.
    Lima NY
  8. James
    James New Member
    126
    Jul 2, 2007
    SW sells an industrial primer called Kem Kromic. And when they say industrial, they mean it. Very thick stuff that when it dries it's like having a second roof over the roof. I used Sherwin Williams super paint exterior for the top coat. It is an acrylic paint. Here is the painting process after stripping the caulk. 1) clean with Simple Green and very stiff brush. 2) Rinse and allow to dry. 3) Clean with a dewaxer/degreaser available at automotive store 4)Prime and allowed to dry for 72 hours. 5)Wipe with damp lint free cloth. or clean again with the degreaser/dewaxer 6) Paint and re-caulk.
    The paint job will look as factory as you can get with a roller. You may want to use a thick nap roller to hide any imperfections.
    James
    91 Coleman Roanoke Royale
    "A Bad Day of Campin Always Beats a Good Day at Work"
    Edited by - James on May 15 2008 23:57:24
    Maycat likes this.
  9. James
    James New Member
    126
    Jul 2, 2007
    Oh yea. You should also use a scotch brite pad to scuff up the surface before you clean the top. The reason I used the Kem Kromic primer was because the paint had a few spots were the bare aluminum was showing through. The paint store said that spot priming would not give me good results so I did the whole roof.
    James
  10. newbiecamper
    258
    Apr 7, 2007
    SE Minnesota
    scuffing is probably the most important step. also degreasing, cuz if you dont ,you'll see what 'fish-eyed' means. Spot priming doesnt work well on cured paint. it may cover nice, but will have a different sheen in those spots.
    `98 Ranger
  11. Cindy F
    Cindy F New Member
    383
    Feb 24, 2008
    I just went over the whole box with my power sander (lightly), washed and dried throughly and painted with Rustoleum enamel spray paint. I bought some Rustoleum clear coat to go over it but didn't have time to put it on before we left for Orlando.
    I was worried about finishing the paint the night before we left then driving 9 hours down but, even after 9 hours down and nie hours back THEN 4 days later 9 hours down and 9 hours back again....the paint still looks like I just sprayed it on.
    Now that I've said that, it will all melt off tomorrow. <img src=../Images/icons/icon_smile_big.gif border=0 align=middle alt="Big Smile">
    <img src=../Images/icons/icon_smile_hardhat.gif border=0 align=middle alt="Major Mods"> Cindy
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp"> 1985 Starcraft Galaxy 24
    <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle"> 1997 Jayco Camper Van
    Nights camped in 2008 14 (soon to be 17!)
    http://community.webshots.com/user/CFredRN?vhost=community
  12. christate1970
    266
    Sep 9, 2006
    I painted my Pop up one year ago and so far its holding up well. It has survived a Seattle winter. I have pictures on my webshots page.
    2005 Kia Sorento
    1980 Coleman
