POOP IN THE PUP! (A Truly Crappy Thread)
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by BikeNFish, Dec 14, 2018.
Do you poop in the pup?
  1. Absolutlely! That is why I have it!
    15 vote(s)
    21.1%
  2. Sometimes. Only in an emergency.
    24 vote(s)
    33.8%
  3. No. Never.
    29 vote(s)
    40.8%
  4. What a terrible question.
    3 vote(s)
    4.2%
  1. Toedtoes
    Toedtoes Well-Known Member
    1,331
    942
    May 28, 2018
    Yep. Really. :)
    You'll hear/read folks go on about needing to break down the solids and TP. TP will dissolve without help (just stay away from Northern) and the solids just need water in the tank to keep from solidifying to the tank (the poo pyramid). A bit of dish detergent helps against that solidifying and is cheap and always on hand.
  2. kitphantom
    11,499
    709
    It took us some trial and error to find the chemical that works best in the 10 gallon black tank in our TT. Odorlos is what works for our water, body chemistry, and amount of use. Not scented, which is great.
    We usually use Scott RV toilet paper, along with Costco septic safe TP. We now only flush poo-ed paper, other paper and wipes get tossed in the wastebasket and into the dumpster. We used that routine & an absolute minimum of water, the first time when we were trying to eke out 10 nights on that 10 gallon tank. It worked well, so we continue to follow it. I think we get away with using a minimum of water on those longer trips because we dump and rinse ASAP, and usually have a good long drive to agitate it all before we get to a dump station. (On shorter trips, we try to gauge it so we end up with full tanks at the end of the trip, if we have water hookups it's easier to do that. This year, we also filled the tanks with mostly fresh water once we got home, after we had a less-than-an-efficient dump angle at the end of a trip. that worked so well that we decided we probably should try to do a fill with fresh water and dump once a season or so.)
  3. J Starsky
    J Starsky Well-Known Member
    619
    389
    Aug 3, 2017
    East Central MN
    It's just warm enough so it will not freeze upon exit [LOL][LOL][LOL]
    kcsa75 likes this.
  4. emoney
    emoney Well-Known Member
    880
    447
    Jul 7, 2018
    Whole reason I bought the TT that we have is that it has a “full” bathroom. There’s a door, a window and an overhead vent with fan. If the need arises it gets used. Having said that, I’m pretty regular so CG facilities are option #1.
  5. Halford
    Halford Well-Known Member
    3,557
    544
    Sep 28, 2011
    Santa Clarita, California
    I just cleaned out the Thedford cassette portable tank no poop in there!
  6. Muller 5
    Muller 5 Active Member
    300
    118
    Jan 6, 2019
    STL
    We don't have a toilet, and we are used to tenting, so a bathhouse is no big deal. That said, my 3 year old is just beginning to potty train so his potty making the trip with us is a strong possibility.
  7. brwarrior
    brwarrior Active Member
    152
    65
    Mar 26, 2017
    Clovis, CA
    I paid enough for the beast I'm going to use everything in it. I haven't had a problem with the 12 gallon black tank. Though the first trip it did get a little...odoriferous on the last night (#5) & morning. Dumping the grey though was a PITA. 1.5" instead of 3". That's been remedied with some adapters.
  8. Rusty2192
    Rusty2192 Well-Known Member
    791
    279
    Jul 30, 2014
    Kentucky
    My son uses the porta potty all the time. I’ve only had to use it for #2 once myself, but had no issues with it at all. So my first choice is the bathhouse, but I’ll have no hesitation to use the porta potty if need be. I’m personally a fan of good chemicals and RV TP. Only once have I still had any solids when dumping, be it TP or otherwise, even after just a short weekend. And that one time was because it was used shortly before dumping. I don’t think it would clog, just make it less pleasant to dump.
    Since it’s usually just my son and I camping, from the time he goes to bed till he wakes up I’m pretty much tied to the campsite so the porta potty has been a life saver, especially when on the inside of the loop and not backing up to the woods.
  9. Sjm9911
    3,408
    1,602
    The problem with kids , even potty trained ones is when we pass the facilities and i ask do you have to go, i get no. As soon as were back at the camp sight, or in bed, they have to go. So the toilet is a god send. Not to mention if you have a few beers, its so much easier then walking.......
    Orchid, Rusty2192 and neighbormike like this.
  10. kitphantom
    11,499
    709
    @Sjm9911 - maybe that's an opportunity to teach "camper's rules" - if there's a restroom, use it whether you think you need to or not.
    The related rule is "see a gas station, fill it up". (Usually only enforced when we're at half a tank, but sometimes sooner, depending on where we are.)
  11. Sjm9911
    3,408
    1,602
    Lol, try telling that to a 7 yo. 6 at the time.
  12. kitphantom
    11,499
    709
    I don't have kids, but my parents taught me that when they took me traveling every summer. I started traveling when I was 6 months old, so I do't remember the first lessons. (I do remember my potty chair in the back of the car when I was about 3.)
  13. Sjm9911
    3,408
    1,602
    It goes like this , i say, go to the bathroom before we leave, its a long drive. As soon as i hit the highway, about 15 minutes later, i get, daddy i have to go potty. I said why didnt you go when we were home. Answer, because i didnt have to then.
  14. Toedtoes
    1,331
    942
    May 28, 2018
    My Mom told me once "i'm sorry I got mad at you when you suddenly had to go to the bathroom when we got on the road".
    When she got older, she found that she would suddenly have to go to the bathroom fifteen minutes into the trip.
    I was nice, I never said "why didn't you go before we left".
    Remember that kids' and old folks' bladders don't hold as much or as well as "young adult" bladders. There may be absolutely no water in the bladder at 10 am, but 15 minutes later it is suddenly full. And when their bladders are full, they need to empty RIGHT THEN. Be nice a remember everything comes back around.
  15. Halford
    3,557
    544
    Sep 28, 2011
    excuse me off to restroom
    Sjm9911, Toedtoes and neighbormike like this.
  16. neighbormike
    1,868
    1,143
    Oct 6, 2012
    WI
    You should have gone before you logged on! [LOL]
  17. Halford
    3,557
    544
    Sep 28, 2011
    wont be long before I say this to you! [Guitar]
  18. neighbormike
    1,868
    1,143
    Oct 6, 2012
    WI
    Trust me, I know! Night time "trips" are no stranger... Potty in the tt seems like more a necessity than luxury! That being said, I have always made things work... a big part of me still misses tenting! I like to think the way I camp hasn't changed since I was 16 - I just sleep in something different.
    PointyCamper likes this.
  19. Grandpa Don
    Grandpa Don Active Member
    168
    59
    Sep 5, 2018
    Okay, I'll add my story and vote to this old thread. I have a Porta-pottie in my Popup. I'd use it for both if I had to. But mostly I have to get up a couple times a night just to urinate. At my age it is a fact of older life. Most of the time I'm boondocking it and there is not another soul around for miles. That when I will just dig a deep hole in the ground and let her rip.
  20. BillyMc
    BillyMc Well-Known Member
    628
    255
    Mar 25, 2018
    #2 isn't forbidden so I'm sure someone will at some point. I empty the tank, but the rule is if you poop in it you empty and clean it. So far everyone has gone somewhere other than the PUP toilet.
