Propane leak?
Discussion in 'Propane - Got Gas' started by JimmyM, Sep 3, 2017.
  1. JimmyM
    JimmyM Well-Known Member
    1,216
    39
    Jun 5, 2014
    Boston, MA
    I switched from 20# to 30# tanks a few months ago. I think I might have a leak though. I went through 1 30# tanks in a few months. When I open the top of the hard plastic tank cover, and stick my nose in there, I get the faint whiff of propane.
    I checked with soap & water a couple of months ago and didn't see any bubbles. But maybe I wasn't thorough enough.
    Has anyone used a propane detector?
  2. Douggro
    Douggro Active Member
    258
    52
    Jul 26, 2017
    Seattle, WA
    Haven't used a propane detector, just the soapy water. Re-check all the hoses, connection points and fittings - and don't forget the regulator(s) and tank valves.
  3. Customer
    Customer Well-Known Member
    2,206
    74
    Jun 5, 2014
  4. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    A manometer will help me set the low pressure side of the regulator but it isn't going to help me find a leak.
  5. Antipodes
    Antipodes Call me Paul
    647
    43
    Jan 28, 2015
    Christchurch, New Zealand
    Don't have one myself but have used one for work.
    They are pretty good but different types will give different results.
    If you are looking for one, try and find one that pulls the air in through a hose.
    If will also need to be very calm (Indoors preferably) and you need to get around the system pretty quickly. If there is a leak it will diffuse quickly and make it harder to pinpoint exactly where.
    May take a couple of goes to get the exact position.
    I have seen someone use a ultrasonic injector and then detect where the noise is coming out of the pipe, but I think that won't really work for this scenario.
    But generally the old soapy bubbles have worked for me.
    The valve itself around the gland??
  6. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    I got a couple of squeeze bottles and made up a soap solution. I bathed every fitting and hose with the stuff from the tank's threaded collar for the valve to the distribution block under the camper. Nothing. I cupped the solution in my hand and covered the regulator vent, nothing.
  7. rabird
    6,066
    62
    TX
    1st stage vent is a tiny hole. Valve steam of service valve.
  8. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    I bathed EVERYTHING. Every seam, every line, everything.
    Bottle neck, bottle valve: vent, safety, gland.
    I hosed down the LP line running back to the distribution block and all ports off that. Checked lines at fridge & water heater. Sniffed around space heater. checked the propane grill line.
    No bubbles anywhere. There's only one more thing I can check. I checked the changeover lever, but didn't check it in both directions.
  9. rabird
    6,066
    62
    TX
    why can't test for a leak with a manometer with the service valve shut and the pressure dropped to 8"?
  10. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    That would tell you that there is a leak somewhere. It won't help you find it.
  11. rabird
    6,066
    62
    TX
    not only will it confirm a leak, it can be used to determine how big a leak.
  12. Yak
    Yak Active Member
    1,153
    21
    Apr 18, 2009
    Not trying to be a wiseazz, does size really matter when it comes to a propane leak??
  13. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    Yup. I have a leak. I put a propane gauge between the tank and propane line. Turned everything on, then shut the valves. It leaked down over night.
  14. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    I'm using caps and plugs to isolate the leak. Testing one of the hoses now. Preliminary test immersing the hose in water showed no bubbles. I'm going to do the same thing with the other hose and the regulator.
  15. kitphantom
    10,111
    143
    How old are the hoses and regulator? The hoses on our '15 TT started to check after 3 years, we replaced them with metal braided ones a couple of weeks ago. (If nothing else, less susceptible to animal gnawing, though we have not had issues with that.)
    If the issue began when you changed to the 30# tanks, maybe the problem is in those. It's probably not cheap, but you could take them to one of the places that re-certify tanks to have them checked out. (We have yet to have our tanks re-certified, we bought a new tank when the one aged out for the gas grill, then got rid of the gas grill. So far, none of the ones on our pups and TT have gotten too old, at least before selling the pups.)
  16. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    How timely your post about hoses and regulator. I found 1 hose that came with the camper (it's a 2015) that had a tiny pinhole leak. I've resorted to immersing stuff under pressure into a bucket. I had a spare, checked it, no leaks.
    So I reassembled everything with yellow tape and sank the whole thing in water. Hoses and regulator.
    Looks like the HP and LP vents are leaking. Very slow, but leaking nonetheless. This is a 5 year old Marshall MEGR-253
    https://photos.app.goo.gl/efe8YV2lyJwwj8tf2
  17. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    I just checked again and bubbling has slowed dramatically. I'm going to let it sit over night and watch the pressure gauge
  18. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    The tanks are not leaking. And IIRC we went through more propane than I thought we should have on our trip last year with the 20# tanks. I bubble checked the 30# tanks and valves. They're good.
  19. JimmyM
    1,216
    39
    Jun 5, 2014
    Boston, MA
    The bubbling at the regulator has stopped completely. It must have been water filling interior spaces and displacing air.
    I did notice that the hose that I thought was good. has a tiny tiny little hole.
    There was a little bubble clinging to the hose. I touched it to dislodge it and a few seconds later another bubble was starting to form. It grew over the course of a minute and a dislodged it again.
    So I'm going to order new hoses.
  20. JPBar
    JPBar Well-Known Member
    1,251
    232
    Sep 22, 2016
    Texas
    Good to hear, sounds like you got this issue solved.
