Propane smell
Discussion in 'Miscellaneous Repairs & Maintenance' started by montanacruiser, Apr 19, 2017.
  1. montanacruiser
    montanacruiser Member
    48
    Apr 19, 2016
    Hi all, I have been starting to smell propane when the valve is open. Cant smell it when it is shut. The smell is coming form right around the propane regulator. Cant tell exactly where. Any Ideas?
    Thanks
  2. Antipodes
    Antipodes Call me Paul
    733
    69
    Jan 28, 2015
    Christchurch, New Zealand
    Get a brush some detergent mixed with the same amount of water and brush it over the components you think are leaking including the valve and hose fittings.
    If it is leaking you should see bubbles expand almost immediately around the leak.
    Once found repair or replace as required. (Under the regulator is the vent hole, make sure you brush over this also)
  3. Osmia
    Osmia New Member
    Dec 7, 2016
    Be sure the valve is opened all the way, otherwise propane could leak around the valve stem. If this doesn't solve the problem, you may indeed need to replace the regulator.
  4. Antipodes
    733
    69
    Jan 28, 2015
    If your valve is leaking when partially opened, then it is faulty and should be replaced.
