quick connect on popup.. are they all the same?
Discussion in 'Propane - Got Gas' started by DirtyBacon, Sep 25, 2018.
  1. DirtyBacon
    DirtyBacon New Member
    Sep 20, 2018
    We just purchased a 2007 Fleetwood Westlake. It has a propane quick connect on the side. Are the propane quick connects all standardized or are there different types? If there are, how do I know which type my PUP has?
  2. neighbormike
    1,586
    813
    Oct 6, 2012
    WI
    They are different between manufacturers.
  3. generok
    generok Well-Known Member
    2,276
    413
    Feb 7, 2013
    Anchorage, AK
    Yup, different. Even if they will fit in the quick disconnect fitting, the internal parts need to match such that it opens the internal spring loaded valve. There are likely numbers on the quick disconnect parts, they need to match. I STILL have the one I tried, but wouldn't allow gas to flow.
  4. rabird
    6,370
    174
    TX
  5. jmkay1
    3,918
    917
    Also to note that on a fleetwood the outside port is high pressure.
  6. rabird
    6,370
    174
    TX
    not '05-'07, not all series/years, ...
    there are some fleetwoods with an outside reg high pressure threaded connection, they would not be quick connects.
    check the parts books https://colemanpopupparts.com/pages/parts-books
  7. Sjm9911
    2,355
    898
    I thonk the screw type disconnects on the outsode of the colman are high pressure. The quick disconnects are low pressure.
    Raycfe likes this.
  8. Sneezer
    1,322
    378
    I think it was around 2003 when they standardized. My 99 has the older one which has a larger internal diameter opening but externally they are the same. I adapted mine with a plastic sleeve from a pen so it will activate the newer connector.
  9. Raycfe
    14,009
    951
    Caution I know that some of the ones Amazon sells don't work/connect. Just watch out for that noname stuff.
  10. rabird
    6,370
    174
    TX
