Rear porch storage
Discussion in 'Cargo Carriers / Bike Racks / Other Storage Option' started by RollTideRick, Jul 10, 2017.
  1. RollTideRick
    RollTideRick Member
    40
    May 31, 2017
    Did you ever think about a rear porch? This is a great place to use for transporting certain lightweight items, coolers, chairs, and other items. This is on a 2000 Flagstaff 208. IMG_20170710_110402.jpg
  2. eoleson1
    eoleson1 Well-Known Member
    1,470
    196
    Jul 5, 2011
    Macomb County Michigan
    Looks pretty ingenious! Is it welded or bolted? Did you reinforce the bumper at all to do this?
  3. Sneezer
    Sneezer Active Member
    983
    235
    That is where my gray water tote travels. I have a 25 gal one, too big to fit under the trailer on a custom rack, and I don't use a truck so no pick up bed storage. I bolted a Rubbermaid garage storage wall rack to the bumper, and bought 3 of the large gear hooks. They are just the right size for the tote to sit on, and I run 2 ratchet straps across to secure it. Works great.
  4. RollTideRick
    RollTideRick Member
    40
    May 31, 2017
    I wel
    I welded small channel to the main frame rails, angle bolted to the outside rails, with welded fishplate, the piece across the back rests on top of the pieces welded to the frame rails. The 5/4 boards lay free with 1/4 inch square stock welded to the outside angle. Will send more pics after the storm!
  5. RollTideRick
    RollTideRick Member
    40
    May 31, 2017
    Notice the 1/4 bar stock welded to keep the 5 1/4 boards in place. Small channel is welded to the frame rails that the bumper is connected to. These pieces run all the way back to the rear piece. Outside angle is bolted. IMG_20170712_201152.jpg IMG_20170712_201152.jpg
