Recomendations for cordless drill?
Discussion in 'General Camper Setup / Take Down' started by SteveP, Jul 6, 2017.
  1. bols2Dawall
    bols2Dawall S.W. Ontario
    1,346
    83
    May 19, 2010
    FYI - you might still want to hand crank the last bit so as not to ram the roof up to its upper limits (lowering too)
  2. jnc
    I use a drill on the lift, stabs & tongue jack and have found it very easy to feather the trigger for soft stops.
  3. CampStewart
    CampStewart Member
    63
    33
    Nov 3, 2017
    Any company that says they are offering 20v power tools is just lying to you. They are using the same marketing strategy that vacuum companies do that claim 6.5 horsepower from a 15 amp electric motor. The companies claiming 20 are in reality offering 18 volts. Don't take my word for it search the net for yourself. If you want the best, currently Makita and Milwaukee are fighting hard for the title. People who own DeWalt may protest but no one I have seen in the trades currently has moved from Makita or Milwaukee to DeWalt but I have seen plenty move from the older 18v and the new pretend 20volt DeWalt to the other 2 brands. If you are buying only a cordless drill and only to raise and lower your camper I would look at the highest torque rating and the slowest rpm. Battery life is greater in the premium brands than in the cheaper ones. They use more expensive more durable cells.
    Fbird likes this.
  4. Sharpie
    Sharpie Member
    42
    Nov 2, 2009
    Ontario Canada
    I have a Bosch HDH181 2 speed drill it has 735 inch pounds of torque. It works great It 18 volt lithium ion battery. Have had it for 4 years with the same batteries. Works great.
