Removing Worthless 1.9 Cu ft Dometic Frig
Discussion in 'Refrigerators and Coolers' started by Anthony Hitchings, Jun 7, 2019.
  1. Anthony Hitchings
    219
    77
    Mar 2, 2019
    We will be removing the worthless 1.9 Cu ft Dometic Frig - which had checked out 100% in our driveway, but in practice cannot stay cold enough in hot weather - another fine product from "Bastards Incorporated" (motto: "we make your life more difficult")
    It gets removed Sunday, along with the heater, for a rebuild to accommodate an Engel 12V coolbox running off our 135W solar system - this Engle (used) was a last minute purchase from friend in Nevada - it saved the trip. The propane heater gets reinstalled further aft. We may ultimately use the Engle to freeze water into ice and use our YETI as the Frig (powered by ice blocks). Then we have the best of both worlds. Cold beer and ice.
    PopUpSteve and Sjm9911 like this.
  2. Sjm9911
    3,414
    1,605
    Lol ,more of a rant then a post but i like it! Who can complain about cold beer and ice! Go for it and post results please!
  3. Anthony Hitchings
    219
    77
    Mar 2, 2019
    Not just a rant - its a bad device, at Jacob Lake we were talking to a couple who had been on the road in their Aliner for three years (web-based work it seemed), the lady of the couple noted that the frig was not really a frig, and she had to plan meals around this limitation.
    "Bastards Incorporated" was a regular skit in an Australian TV comedy show back in 1990 - it was right "on the money" (I was working in Perth, OZ).
  4. durhamcamper
    durhamcamper Active Member
    709
    155
    Apr 21, 2010
    Pickering, Ontario
    Huh. Our Dometic fridge works flawlessly, even without the fan mod.
  5. bheff
    bheff Active Member
    302
    86
    Feb 24, 2011
    This
  6. Sjm9911
    3,414
    1,605
    I read stuff on both sides. As with the ac thread, some work better then others. Mine , works but not great, i reson thats because its old.
  7. tfischer
    tfischer Well-Known Member
    3,269
    798
    May 21, 2014
    Our 3-way fridge often gets so cold on propane that it starts freezing things and I have to turn it down.
    generok likes this.
  8. gladecreekwy
    516
    489
    Sep 25, 2016
    Ours has never been cold enough. Pulling it out and building a cabinet
  9. David Blackwell
    David Blackwell Member
    56
    32
    May 10, 2017
    San Diego, CA
    IMHO, as well as on-line research (see below), the ability of all (most?) ammonia absorption refrigerators are limited to cooling 50-60 degrees (F) below the ambient temperature i.e. at 100F your food is at 40-50F. I also recently removed/replaced my 3-way Dometic RM2354 (2017) with an IsoTherm Cruise 130. It was a huge improvement in storage i.e. from 3 cubic feet to 4.5 cubic feet. The new unit was slightly smaller than the Dometic but reclaimed a lot of the space used by the absorption system.
    https://en.wikipedia.org/wiki/Absorption_refrigerator
    http://www.sundancecustomrv.com/Ammonia Absorption Refrigerators.pdf
    https://www.thedometicguy.com/blog/dometic-refrigerator-wont-get-cold-enough/
  10. Blackripley
    Blackripley Member
    54
    28
    Jul 21, 2018
    Goleta Ca
    How are you going to vent the heat from the Engel 12V coolbox?
  11. generok
    generok Well-Known Member
    2,378
    527
    Feb 7, 2013
    Anchorage, AK
    If you relocate the furnace, won't you have to punch a new hole in the sidewall to vent it, and deal with the old hole?
  12. Anthony Hitchings
    219
    77
    Mar 2, 2019
    Well - we did nothing special for handling hot air on the Cedar Mesa trip, and it was not a problem. On the upcoming Yellowstone trip we are trying out putting the Engel end first into the old Frig space - which locates the Engel's cooling holes right by the old Frig exterior vents - ain't that handy !? We do have a lot of opening screened windows in our Aliner - and a Fantastic Fan, we can cool it off really quickly. The propane frig never got below 54 deg F in Laughlin, NV.
  13. roybraddy
    roybraddy Well-Known Member
    2,005
    641
    Mar 23, 2016
    King George, Virginia
    My small fridge does not have the freezer part. We only use to keep things cool like soft drinks etc... We use our COLEMAN 5-day Ice Chest in the back of our truck covered truck bed to keep things frozen. Meats and such are kept in a plastic box with lid sitting on top of the cold ice...
    We usually only get three days of freezing so this is one of our burdens doing it this way... In three days we are having to head back to town for more ice and more meats...
    It really works out good for us as in three days others things we like to have around are used up as well... Most often we are OFF-GRID back in the woods somewhere and for one of use to leave our camp setup is sort of a problem Who stays or who goes etc... Not easy to tear down the camp site just to head back to town for something...
    A lot of pre-planning here...
    So far it works out pretty good for us an dthe way we like to camp out mostly off-grid...
    Our fridge is useful for us to keep. Makes a great cooler... I cut out some of the bottom compartment wire shelf for larger bottles like milk and tall soft drinks etc...
    When we first start out on out trips we usually have two full large milk cartons filled with frozen ice. Then when we get about an hour out form our destination we will switch the fridge to 12VDC and it is real cool when get to the camp site. The frozen milk cartons is then our cold drinking water as we need it...
    Roy Ken
