replacement 12' awning
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by cr500taco, Apr 20, 2019.
  1. cr500taco
    cr500taco New Member
    17
    Nov 4, 2013
    Any recommendations on a replacement 12' awning?
  2. kcsa75
    kcsa75 Well-Known Member
    2,456
    1,008
    Sep 9, 2013
    Kansas City
    ezakoske and cr500taco like this.
  3. roybraddy
    roybraddy Well-Known Member
    2,005
    641
    Mar 23, 2016
    King George, Virginia
    My awning bag also has finally succumbed to the Suns UVs... I was just strapping down my awning to the roof for travel using those 1/2-inch web ratchet strapping across the top of the popup trailer. I finally just removed the awning from the trailer...
    I'm thinking of picking a 10x10 or 11x11 patio awning and just scoot it up close to the popup trailer door and see how that works for awhile... I would use the straight legs type... However it seems all of these patio covers are not high enough to allow you to open the popup trailer door so if I continue down this path I will want to extend the legs perhaps. Had the idea of clamping two of the legs to side of the camper. These are cheap enough from WALMART on sale a lot $60 or so... Even if you didn't use them to sit under just outside the trailer door they would make a great cover over the picnic table...
    Google image
    Roy Ken
  4. crackerJack
    crackerJack Well-Known Member
    1,102
    278
    Jan 6, 2014
    Scottsville, KY
    I swapped my OEM Coleman awning with a new Dometic Trimline.
    It sets up much easier and has attachments for the associated add a room.
    I did have to drill some holes on the legs to allow some lower height settings.
    cr500taco likes this.
  5. cr500taco
    17
    Nov 4, 2013
  6. GreyFox
    GreyFox Well-Known Member
    938
    412
    Oct 10, 2018
    S Ontario
    Downside to the Dometic Trimline awning is it's not made up of individual poles but rather an entire left side assembly connected to a right side assembly with a centre bracket. Bend a leg or rafter pole and you have to replace the entire left (or right) assembly, which is quite costly.
  7. ezakoske
    ezakoske Active Member
    498
    57
    Nov 30, 2014
    Escondido, CA
  8. Dingit
    Dingit Well-Known Member
    719
    304
    Mar 8, 2017
    Anyone happen to know what these standard bag awnings weigh? I'm thinking about upgrading mine (something about the way it lays torn on the floor of my garage just isn't working out) and I can't find any weight listings online.
  9. seawolf68
    seawolf68 New Member
    24
    May 24, 2014
  10. theseus
    theseus Centerville, OH
    2,776
    375
    Feb 6, 2007
    Centerville, OH
    I prefer the Campout by Carefree of Colorado. Had one on my Palomino and miss it greatly on my current pup.
  11. Brian Martinez
    Brian Martinez New Member
    Jun 9, 2019
    I am looking for a replacement awning. Do the legs, stitching and bag seem sturdy? The stitching on the OE Jayco awning started to disintegrate (2010 model).
    I have looked online at the Carefree and Dometic and they look similar. Any opinions would be appreciated
  12. kcsa75
    2,456
    1,008
    Sep 9, 2013
    Kansas City
    The awning we bought was a Shademaker. Everything was included and top quality. The support set up (legs and poles) all folds into one assemble that is permanently attached to the awning so there are no extra poles to keep track of and it's much easier to set up.
    I would high recommend it.
  13. theseus
    2,776
    375
    Feb 6, 2007
    Centerville, OH
    I currently have a Dometic. As I have said I prefer the Carefree. No guy lines and everything folds up into the rail.
  14. Brian Martinez
    Jun 9, 2019
    Thanks
  15. Brian Martinez
    Jun 9, 2019
    Thank you
  16. CamperChrissy
    CamperChrissy Well-Known Member
    529
    250
    Nov 25, 2016
    Chicago suburbs
    Do you have any pictures of how the legs fold up in to the front rail? I'm looking at buying one of these also and I'm trying to figure out the difference between the Classic and Supreme.
  17. kcsa75
    2,456
    1,008
    Sep 9, 2013
    Kansas City
    Sorry, no photos. I started to try to describe how everything goes together, but the diagrams on the website are much easier to understand. If I remember correctly, the Classic poles are round and the Supreme are square.
    We bought the Classic and there was no issue with the poles being strong enough.
  18. Brian Martinez
    Jun 9, 2019
    Purchased the Shademaker Supreme. Thanks to all who responded with input
    kcsa75 likes this.
