Replacing sideboard, but not roof
Discussion in 'Roof/Floor Repair & Maintenance' started by Dan Noonan, Jun 11, 2019.
  1. Dan Noonan
    Dan Noonan New Member
    Jun 7, 2019
    Hello, my question is.... Can I replace a sideboard without replacing the entire roof? I have one area that ants got into that I would like to replace.
  2. joet
    4,164
    722
    What condition is the roof in? any water intrusion, soft spots, any sag from side to side, what condition is the skin in, one piece or seamed roof, condition of the other side board? Any of these would influence my decision as to rebuild or patch
  3. Raycfe
    14,413
    1,075
    The biggest problem is getting a piece of long plywood to do the repair and be strong. You may have to built a piece by gluing and lapping to pieces together. Many roofs are just stapled together so the the staples will need to be cut to remove the bad wood.
  4. Dan Noonan
    Jun 7, 2019
    The roof is in very good condition, the other side is in good condition the only problem area is on the drivers side panel and where the rear meets the side. As I had said ants got in there. There is no sign of water damage. It is a a seamed roof. Can I just remove the side skin?
  5. Dan Noonan
    Jun 7, 2019
    Does the roof liner just peal away?
  6. Dan Noonan
    Jun 7, 2019
    We are using it on the 4th and I'm selling it after that it isn't really big enough for us. Having stated this would epoxy be a suitable repair? If not can I build a roof before taking the old one off?
  7. WrkrBee
    WrkrBee Well-Known Member
    1,767
    640
    There are Liquid Wood products that you might could use.
  8. Logjammer
    Logjammer Member
    34
    22
    Jan 17, 2019
