Reupholster a jack knife sofa?
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by Spartacus, Apr 16, 2018.
  1. Spartacus
    Spartacus Member
    27
    29
    Feb 12, 2018
    Murray, Kentucky
    Has anyone done it? We are remodeling the inside of our camper but the wife and I are debating on how to best go about updating our sofa. (Jayco refers to ours as an "J-Steel Sofa")
    We have tossed around ideas from fabric paint to, to simply a cover, to removing them completely and using all new material.
    One thing we haven't had much luck on options, is the end of the sofa next to the door. It's a curved wood piece with matching fabric sown around it. It also houses the fire extinguisher.
    Surely someone has done something with theirs besides completely removing it!? j-steel sofa.jpg
  2. Mamie
    Mamie Active Member
    839
    109
    Sep 11, 2017
    LA - Lower Alabama
    Are those cushion covers or, is it fabric mounted to a board?
    I like that drop-leaf on your table.
  3. JPBar
    JPBar Well-Known Member
    1,846
    553
    Sep 22, 2016
    Texas
    I removed mine, storage under sofa was worthless and so was the sofa. If you do remove the sofa you have to use that sofa end to support the wall or make something that will support the wall.....don't ask me how I know this if you know what I mean.
    Spartacus likes this.
  4. Spartacus
    Spartacus Member
    27
    29
    Feb 12, 2018
    Murray, Kentucky
    I'll have to take a picture of the bottom, but it's not mounted to a board. The fabric is connected to the metal framing with spring coils.
  5. Mamie
    Mamie Active Member
    839
    109
    Sep 11, 2017
    LA - Lower Alabama
    My cushions have the board inside of the cushion to use it for a bed with the bottom being some kind of lining instead of the cushion fabric.
  6. Spartacus
    Spartacus Member
    27
    29
    Feb 12, 2018
    Murray, Kentucky
    Finally was able to disassemble the sofa. So theres a metal tubing frame all around the bottom near the edge of material. The actual material end is sown around a thin rod and then there is basically a metal clip bent around the material rod and another metal rod that is attached to the frame tubing. The wife and I have talked about different ways to go about recovering it but think we need something that can be removable so we can easily wash it. (2 kids)
    I was hoping someone had tackled something similar before?
  7. Mamie
    Mamie Active Member
    839
    109
    Sep 11, 2017
    LA - Lower Alabama
    Can you put something like a canvas or muslin on there tight with a stapler if there's wood and then do the cover like a fitted bed sheet so you can take it off?
  8. pasobuff
    pasobuff Member
    391
    21
    Aug 6, 2012
    Upstate NY
    I'll be following this as we have a similar sofa that desperately needs new cushions and a cover!
  9. Spartacus
    Spartacus Member
    27
    29
    Feb 12, 2018
    Murray, Kentucky
    So after much deliberation, my wife decided to get a thicker material and sow them over the existing material. We originally wanted to make them removable to make it easily washable since its a light colored material, but we are just going ahead with sowing them over with a thick material and then applying Scotchguard to help with stain protection.
    jnc likes this.
  10. Mamie
    Mamie Active Member
    839
    109
    Sep 11, 2017
    LA - Lower Alabama
    Can't wait to see how they turned out.
  11. Spartacus
    Spartacus Member
    27
    29
    Feb 12, 2018
    Murray, Kentucky
    Couch is all done! Just need to put it back together and back in the camper.
    57AC9C55-F624-4D03-92F7-30FAF42614AA.jpeg E92C6C13-1D6B-4494-8EFF-18ADAD8049A8.jpeg 727B4504-DE09-4713-BC55-6CAED3F769E0.jpeg 8DB4DFDE-9334-411C-928F-45934B1C07EF.jpeg
  12. Mamie
    Mamie Active Member
    839
    109
    Sep 11, 2017
    LA - Lower Alabama
    That looks great! It's going to make a big difference. I've got several different upholstery fabrics that I already have to choose from. Can't wait to see the difference it will make in my camper.
  13. Spartacus
    Spartacus Member
    27
    29
    Feb 12, 2018
    Murray, Kentucky
    Finally got it back together and in the camper!
    JPBar likes this.
  14. Mamie
    Mamie Active Member
    839
    109
    Sep 11, 2017
    LA - Lower Alabama
    It really looks good. It doesn't look like the same camper.
