Roof side panel repair H-E-L-P!
Discussion in 'Roof/Floor Repair & Maintenance' started by dwhite, Aug 19, 2017.
  1. dwhite
    dwhite New Member
    Jun 7, 2015
    I'm in the middle of a mess. I supported my popup roof putting some 2x12's lengthwise under the ends of the roof. Well, I got the side panel loose and the front of the roof started bending up.
    I go everything that I could bolted back together. I think I can raise the the top to get the pressure off the ends.
    How am I supposed to support the roof to do the side panel? Posts on the inside?
    Help.
    All the Best,
    D. White
  2. kingbain
    kingbain Member
    36
    Jul 3, 2016
    Some people put braces on the benches and supporting the roof with bracing on the inside
  3. dwhite
    dwhite New Member
    Jun 7, 2015
    Finally found a post about using buckets, like the five gallon ones Home Depot sells, and putting the on the bed frames after removing the mattresses. Needed to stack two, one inside the other, and still needed three inches under them to get enough height.
    So far, so good.
    All the Best,
    D. White
    kingbain likes this.
  4. Dusty road
    Dusty road Active Member
    702
    44
    Feb 28, 2016
    Conneaut, Ohio
