Rooftop AC vs Portable AC
Discussion in 'Camper Pre-Purchase Questions' started by Laura Rosas, Dec 26, 2018.
  1. Laura Rosas
    Laura Rosas New Member
    Dec 8, 2018
    Which cools better Rooftop AC or Portable AC?
  2. PopUpSteve
    PopUpSteve Administrator
    18,560
    1,407
    Dec 22, 2002
    Malvern, PA
    Since you said in you previous post that you intend to camp mostly in Colorado, Wyoming, and South Dakota, I would go with the portable AC if any.
  3. jmkay1
    4,428
    1,367
    A rooftop ac cools better not to mention takes way less counter space, but if your camping primarily in the cooler states you can get away with the portable unit.
  4. xxxapache
    2,742
    760
    A rooftop on popup is generally 13.5k btu. Most portables are not that big. Usually 8k to 10k.
    I used a 8k portable in a hardside popup. It would not cool below outside temp in direct sun. With reflective bunk and window covers, it would cool 10 to 15 degrees below outside in direct sun. Add a shade tree and it did well.
  5. Sneezer
    1,439
    470
    I have an 8k BTU portable. On its own it is worthless for cooling the pup. Last summer I had a power issue and only had the portable running for one day. I was in full shade in TX weather during summer and it did not cool at all. This was with full reflectix in the windows and my awning out as well. I wasn't able to cool the camper back down until I got the rooftop unit running again.
  6. Dingit
    Dingit Well-Known Member
    749
    321
    Mar 8, 2017
    Humidity makes a big difference.
    If you're going to TX or VA, get rooftop. If you're in the drier states Steve mentions, you don't need your AC to work nearly as hard and can probably get by with less.
  7. BillyMc
    BillyMc Well-Known Member
    687
    278
    Mar 25, 2018
    Roof top cools much better.
  8. speckhunter80
    4,782
    61
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Cold air sinks, therefore a roof top is better. Rooftops are normally 2.5-3 times the BTUs of a portable AC also.
  9. emoney
    emoney Well-Known Member
    880
    448
    Jul 7, 2018
    There's really no comparison. A rooftop unit, even the smallest, puts out 13,500 btu and in Florida,
    on the beach, in July, when temps during the day were 90 and humidity over 90%, it got WAY too
    cold in the p'up, that I had to turn it off several times. 2 of the days we were there, it rained all day
    and night so we spent quite a bit more time indoors than we had planned. Had I used a portable,
    that would've made for a miserable trip.
  10. GreyFox
    GreyFox Well-Known Member
    966
    436
    Oct 10, 2018
    S Ontario
    If portable units were most suitable for the task of efficiently cooling the interior of an RV they'd obviously have become the de facto standard. They haven't, roof mounted A/C units are the standard.
  11. Halford
    Halford Well-Known Member
    3,557
    555
    Sep 28, 2011
    Santa Clarita, California
    Depends on where you live. I do not have rooftop AC because I live in California which is unnecessary to have A/C at coastal areas even in the summer. But if I want to camp in the desert in the summer I would need AC but I usually do not go outside the coastal areas in the summer. If I do, then portable AC would be the best for me. I do not want to carry dead weight (AC) where it is not needed. I used to have rooftop A/C on my first 2 popups when I lived in the Southern states and A/C was absolute need there. I brought my 2nd popup in California and the AC was a dead weight because I actually never used the it.
    as for you, you can keep portable A/C in garage for those times when you do not need it.
    also if you looking for a portable AC, get the one with 15,000 or higher BTU!
