Rust in toilet
Discussion in 'First Time & New Camper Owners' started by Kbeaman, Oct 11, 2018.
  1. Kbeaman
    Kbeaman New Member
    Jul 23, 2016
    Just bought a hybrid and when we looked at the camper it was winterized. After flushing the system we seem to have rust in the toilet. I clean the rust out of the toilet and it looks fine but a couple days later it’s right back to rust. I’m not sure where it’s coming from but it looks gross!!!
  2. generok
    generok Well-Known Member
    2,276
    413
    Feb 7, 2013
    Anchorage, AK
    Hmm, perhaps it is biological since there's not much to rust in a typical RV water system. Are you running on city water or on the pump off the internal tank?
    If you're running off the tank, have you sanitized the tank and water system? I suspect biological slime over rust. Does it also come out the faucets?
  3. xxxapache
    2,581
    633
    Sounds like pink mold to me. I would sanitize the fresh water system with a mild bleach and water solution and let the toilet sit over night with a bowl of a stronger bleach and water solution.
  4. Halford
    Halford Well-Known Member
    3,509
    484
    Sep 28, 2011
    Santa Clarita, California
    Don't add metal to your meals. It prevents rust. [RTM]
