RV furnace troubles
Discussion in 'Heating / Cooling Systems' started by SgtRon, Nov 17, 2018.
  1. SgtRon
    SgtRon Member
    53
    36
    Jun 7, 2017
    Florida
    New question: Our pup has a Suburban LP heater that I tried for the first time this morning, only blowing cold air. I watched the troubleshooting video, it looks like there are no consumer serviceable parts. I've turned on the LP gas, I moved the thermostat up and heard the fan turn on. I ran it for about 10 minutes, the air never warmed up. Does anyone have any suggestions, or should I just take it to a RV service center?
  2. Martlee
    Martlee New Member
    Aug 15, 2016
    You need a strong battery to ignite the furnace. Have you tried it on AC. Plugged into an outlet that is.
  3. BikeNFish
    BikeNFish Well-Known Member
    2,354
    1,356
    Apr 24, 2017
    Maplewood, MN
    Are you getting gas to your furnace? Light your stove to make sure there is gas flow.
  4. SgtRon
    SgtRon Member
    53
    36
    Jun 7, 2017
    Florida
    Gas is fine, stove lit, trailer is plugged into 110vac., not sure if the fan velocity (sail) switch is functional.
  5. PopUpSteve
    PopUpSteve Administrator
    18,176
    1,130
    Dec 22, 2002
    Malvern, PA
    Could be a clogged gas line. Spiders love making nests in the gas lines right at the injector.
  6. joet
    4,006
    673
    You can always crack the gas line to check for flow
  7. p
    p Active Member
    486
    92
    Jun 9, 2014
    My furnace would not light one night. Tried for hours. It would light for a second then go out. It was like it needed air.
    I realized the steel wool I stuck in the air vent to keep the mice out was still there. Pulled it our...works.
    Several hours of my life never to get back.
  8. generok
    generok Well-Known Member
    2,350
    490
    Feb 7, 2013
    Anchorage, AK
    So, are you hearing the igniter spark? If you are, you likely have a LP flow issue. Either the unit isn't getting gas, or your furnace regulator/valve isn't working correctly. If you don't, you have an issue with the igniter circuit.
  9. SgtRon
    SgtRon Member
    53
    36
    Jun 7, 2017
    Florida
    I hear a " click" which i assume is the igniter attempting to light
  10. SgtRon
    SgtRon Member
    53
    36
    Jun 7, 2017
    Florida
    I'm not comfortable working with LP, I'll leave that to a pro.
  11. generok
    2,350
    490
    Feb 7, 2013
    Anchorage, AK
    Maybe. There should be a couple of clicks. Once the fan is running, and the time delay expires, the LP control valve has to open, probably making a click. Then, the igniter should begin to fire. Atwoods make a double click, three time, and then take a break if they don't light (at least all the furnaces I've owned have that pattern).
    The big question is, where is your furnace in the cycle:
    1. Fan turns on (indicating the t-stat is closing calling for heat)
    2. LP control valve opens (indicating the sail switch and time delay relays are working)
    3. Igniter sparks
    4. Burner lights (indicating LP is flowing and igniter works)
    5. Burner STAYS lit (indicating the thermocouple works)
    6. Burner and fan goes off (inidicating t-stat is opening at set temp)
    Sounds like all you're sure of is #1. It's fairly important to know if you have a control valve issue, or if you have an igniter issue. The latter could be a motherboard issue, the former, an electromechanical issue at the valve.
    It sounds like you're uncomfortable with tinkering with the LP side of the house, so it's probably best to hand it to a service center and say "fix this" and they will, and you will have heat once again. Otherwise, you have to troubleshoot your way through the components.
    Best of luck!
    Fless likes this.
  12. William Freeman
    William Freeman Active Member
    152
    56
    May 5, 2018
    Richburg SC
    My fan was coming on but it wouldn't light - wouldn't even try to ignite. After reading a bunch of threads on here, I removed and touched the thermostat wires together and everything started as it should. Turns out the thermostat on/off switch contacts were misaligned. I played around with bending them a few times until it started working correctly.
    Now that I think about it, I meant to replace that thermostat (and relocate) with a digital one. I guess I'd better go ahead and order one so I can get that done before our trip at the end of the month!
    Edit: I went back and re read my thread when I was troubleshooting. I DIDN'T remove the wires, I just removed the cover and fiddled with the ON/OFF switch because it was stuck. When I did this, the contacts bent and weren't making contact when turned to the ON position. I pressed the contact down so that they made contact and held it there - started up normally. That's when I played around with bending the contact strip until it worked correctly.
  13. Fless
    Fless Active Member
    904
    173
    Aug 14, 2012
    Colorado
    ^^^^ What @generok posted is great basic troubleshooting, step-by-step. It's great to see such well-thought-out info on the forum.
    _
    William Freeman likes this.
  14. Naps
    Naps New Member
    May 14, 2019
    Hi, my problem seems to lie between step#3 and Step#4. I have times where the furnace goes through it's 3 try's at lighting the burner ( I can hear the sparking occurring), but fails and goes into a soft lockout where the led blinks 3 times in a second. I believe I can hear the click of the gas valve opening before hand. The real confusing thing is that by cycling the heat on/off at the thermostat and retrying the furnace, it eventually lights. Once lit it stays running normally and shuts off once temperature is reached.
    The problem is intermittent and happens more than once during the night. Problem happens when hooked up to power so it's not a battery issue.
    I'm thinking it is a propane issue that only occurs at startup. Any suggestions on what to look at first would be greatly appreciated.
    Thanks!
