Should this be replaced?
Discussion in 'Miscellaneous Repairs & Maintenance' started by Jhunt012, Sep 11, 2017.
  1. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    This thin metal piece has a piece of foam under it and there is one at the bottom of each "support piece" that holds the roof up. 2 of the 4 look like this (cracked). When the roof is closed the rubber weather stripping seals on top of it.
    Can/Should these be replaced and what might have caused this?
    Any advice is appreciated - Thanks for your time!
    Jim
  2. tombiasi
    4,195
    226
    I don't see a crack.
  3. neighbormike
    neighbormike Active Member
    593
    150
    Oct 6, 2012
    WI
    Looks to be cracked just below the rivets in the photo, but not sure of its purpose...
    Jhunt012 likes this.
  4. Antipodes
    Antipodes Call me Paul
    760
    76
    Jan 28, 2015
    Christchurch, New Zealand
    They look like aluminium extrusion from you image and look like guide plate for the posts.
    The right hand lug looks like it has broken completely.
    I also see that the bracket has been moving on the rivets and they seem to be at the ends of the holes.
    Looking as this from here I would guess the bracket has failed and should be replaced as the lift post seems to be slopping fwd and back causing the holes to elongate in the bracket.
    The rest of the aluminium extrusion is holding the lift posts in place, but my guess on the brackets in question, is that they reduce the amount of movement the lift post has in the wall and consequently reduce the total roof sway.
    Of course the extrusion under it may also be cracked but can't make out too much in this picture.
    I don't think it is a safety problem unless the lower extrusion is badly compromised.
  5. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    Makes sense that it is in place to minimize movement of lift post. I thought it was almost like a trim piece to cover opening around base of lift post. It's very thin. Do you know if it has a name and/or how to get a replacement?
  6. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    The crack/break is in the rectangular piece at the base of the lift post, Just below the rivet on the right side.
  7. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    I actually found the answer to my question on YouTube if anyone is interested
    KampKarma likes this.
  8. Antipodes
    760
    76
    Jan 28, 2015
    Interesting. Plate is just a holder for the sealing gasket and is intended to move back and forward.
    Good find by you.
    KampKarma and Jhunt012 like this.
  9. 1380ken
    1380ken Well-Known Member
    1,468
    148
    Nov 7, 2013
    Mass
    I would not replace them. I don't think the crack makes any difference.
  10. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    I appreciate your opinion. Now that I better understand their purpose, I certainly won't be in a rush to replace them.
  11. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
  12. mstrbill
    mstrbill Active Member
    432
    74
    Mar 17, 2013
    Austin , Texas
    I would replace them, they keep crap out of the lifter posts. Which could cause the lifter posts to bind during lifting or lowering the roof.
