simple brake controller?
Discussion in 'Etrailer.com Trailers and Towing Forum' started by wjquigs, May 23, 2018.
  1. mattlreese
    mattlreese Active Member
    169
    44
    Sep 6, 2017
    You would need a seperate 7 way installed in your car as the brakes require a power wire to the battery. etrailer sells some simple kits where you plug in your 4 pole plug to the 7 pole plug and all you need to do is run a wire to the battery. They are quite easy to install.
    I would then recommend a prodigy wireless brake controller. They are pricey but its much more straight forward to use then wireing in a brake controller inside the car.
  2. Ken Lane
    Ken Lane Member
    82
    39
    Apr 16, 2019
    Knoxville TN
    I have to recommend the Curt Echo, control everything via your smart phone and brake pedal. Plug in, pair the Bluetooth and rock and roll.
