Sink drain hose failed
Discussion in 'Miscellaneous Repairs & Maintenance' started by odin1701, Mar 20, 2017.
  1. odin1701
    odin1701 New Member
    Mar 20, 2017
    I'm curious if anyone else has had this issue. The drain hose from my sink to the outer drain in my Flagstaff MAC failed. This was after very little usage, setup maybe 15 times. It's extremely disappointing and also Forest River will not warranty it.
    Has anyone else had this issue and are there any recommendations on a better hose as this drain hose is obviously insufficient for the usage or it was installed incorrectly.
    Also, anyone know how to get into this compartment so this can be more easily repaired?
    Photos:
  2. crackerJack
    crackerJack Active Member
    815
    87
    Jan 6, 2014
    Scottsville, KY
    That is the same junky hose Coleman used on the fresh water tank fill.
    Find some flexible tubing, that won't kink easily, at any hardware store with the same ID inside dimension.
  3. odin1701
    odin1701 New Member
    Mar 20, 2017
    Yeah, they are sending me a new hose...I'll just use that as a guide for length to get something decent because I think this hose is crap.
