So much stuff
Discussion in 'General Camping Discussion Forum' started by crazymama30, Jul 11, 2018.
  1. crazymama30
    crazymama30 Active Member
    317
    122
    Apr 1, 2017
    I am currently cleaning out the old pup and going through stuff and putting stuff in the new stuff. When I bought the old pup it came loaded with camping gear, so I literally have not seen some of this stuff. I cannot believe how much stuff I had packed into that little pup. Nor can I believe how dirty it is. My goodness I have a lot to get done before I can sell it, not to mention I need to find the title.
  2. Dusty road
    Dusty road Active Member
    730
    54
    Feb 28, 2016
    Conneaut, Ohio
    Ours came loaded too. Three years later and we're still finding things that we didn't know we had.
  3. michigan_camper
    michigan_camper Member
    47
    Aug 16, 2016
    We went through the same thing. Our old camper we had for 17 years and when we went to empty it, we were amazed at how much stuff accumulated in there.
    What is the new camper?
  4. crazymama30
    317
    122
    Apr 1, 2017
    New one is a 2004 Rockwood high wall. Much bigger, has a slide out and a 3 way fridge, oven, sink, and even microwave
  5. Sjm9911
    2,364
    901
    Mine came loaded with the previous owners stuff! It was like rusty gold.
    jnc likes this.
  6. nineoaks2004
    6,016
    2,210
    Graceville, Florida
    My biggest problem is the DW, she thinks that there should be no place that doesn't have something crammed into it, I go thru before every trip and place a lot of unneeded items in a large tub labeled Trailer stuff. As a EX LD backpacker my philosophy is if it is not used on two trips, it goes in the tub because it is not needed, also I try to have everything have at least 2 uses. I use to cut the handle off my toothbrush because ounces make pounds, I am not quite that weight conscience an longer.
    Good luck and happy camping with the new camper.
    sawdusty and neighbormike like this.
  7. crazymama30
    317
    122
    Apr 1, 2017
    I finally got the stuff out of it, now need to clean it and wash the sleeping bags. But for tonight? I am done and having an adult beverage.
  8. michigan_camper
    47
    Aug 16, 2016
    You will like the high wall. Thats what our new one is too, and we enjoy it.
  9. crazymama30
    317
    122
    Apr 1, 2017
    I like it already and I have not even camped in it! I like it even more after I got it back from the shop and it is do easy to set up.
    Sjm9911 and jnc like this.
