So, what did you do for your camper, January 2016
Discussion in 'So, What Did You Do For Your Camper This Month ?' started by kitphantom, Jan 1, 2016.
Thread Status:
Not open for further replies.
  1. kitphantom
    10,763
    318
    Happy New Year to everyone.
    Here's your battery charger reminder, for those doing the monthly off-season upkeep. Ours were charged a couple of weeks ago, when we finally got them off the TT in storage, but we're going to put them on the charger again today to get back on track.
  2. niagarafam
    niagarafam Active Member
    2,168
    Jan 25, 2014
    Thank you! I am pulling the battery and putting it on the "tender" today. I made a large list of maintenance items for the spring. It's a lot of caulk and rtv work, so I will wait for warmer days. That's my excuse for now anyway.
  3. kitphantom
    10,763
    318
    Waiting for warmer weather for some tasks here too. We'd planned to remove tape residue and give the TT a quick wash, then put the cover on. We brought it home from (temporary) storage Christmas Day, just as the winds were ramping up, with snow arriving the next day. It has pretty much hovered at or below freezing since then, so no work on washing or covering. We've been dealing with snow, ice and melting snow creating an ice sheet in the driveway - with sun, things melt even when it's cold - and it got all the way to 40 yesterday.
    We've been in and out of the TT all week, since some items didn't get removed or replaced while it was at storage - at least I remembered to pull all liquids before freezing weather hit.
    I added a bit of pink to the toilet bowl, since it had mostly evaporated, then added seal conditioner (which is OK to use with antifreeze). Looked odd - deep pink + blue conditioner = weird purple.
  4. kcsa75
    kcsa75 Well-Known Member
    1,185
    328
    Sep 9, 2013
    Kansas City
    I thought about it.
    Our camper is in storage so probably won't lay eyes on it again for a couple or three months. In the meantime, we want to replace all the counter tops. I bought a 4 x 8 x 1 sheet of marine-grade plywood and had it cut to roughly the dimensions I need. If/when the weather warms up, my plan is to get everything cut to size and finish with stain and seal. Then we'll do the replacing during our first trip in the spring. [:)C]
  5. WeRJuliIan
    936
    85
    May 15, 2014
    Sarasota, FL
    Started drawing up a list of everything we need to buy/replace/save up for...
  6. gardenbliss
    gardenbliss Well-Known Member
    1,256
    97
    Dec 9, 2013
    San Diego
    I washed the outside vinyl and canvas, organized the inside so I'm ready to go at a moments notice.
  7. Racerm305
    Racerm305 New Member
    Feb 20, 2015
    I raised the body 4" when I relocated the axel to the bottom of the leaf springs and gained storage space when I installed the custom steel wheel wells. The wells went from 10.5" tall plastic to 3.5" steel. I read a thread to change to steel so if the tire blew it would not destroy the plastic wells and damage the cabinets/camper inside. Changing the axel also made it easier to access the pup tire. The hub center is now below the wall of the closed wheel well. Next is finish rebuilding the cabinets.
    We bought the 79 Starcraft under $200 and have replaced the floor, rebuilt the front and back, recanvased, and reconfigured the interior. It's been a project but have taken it out 3 times so far. The goal this year is to expotentionally increase useage. My 3 year old keeps asking when we can camp again (need to add a heater). [DUCT] [MOD] [RTM]
  8. Canufixit
    Canufixit Member
    61
    Nov 4, 2015
    Ok I'm Jealous !! Fl, Ca and others enjoying outside - and I'm waiting for the 7 feet if snow we had last year ... Maybe I can open the camper in late march and start some work.
  9. niagarafam
    2,168
    Jan 25, 2014
    Indirectly related to caring for the PUP, I will be sanitizing the Thetford SmartTote and put it up in storage. We did make a "To Do" list for the Niagara yesterday:
    1. Floor repair behind refer (exposed by refer vents)
    2. RTV roof and all external fixtures
    3. Seal shower
    4. Replace kitchen faucet with metal residential
    5. Brace sink wall
    6. Remove tent stains
    7. Under slide-out metal panel treat with rust convert and primer
    8. GP 27 battery (?)
    9. Lube wheel bearings and adjust brakes
    10. GFCI Replace
    11. Shocks mod (?)
    These are in no particular order, but the caulking, sealing, rust, and lube work have first priority.
  10. kitphantom
    10,763
    318
    Our list of things to be done for next season isn't very long:
    1) new tires - I need to do some research, the original are Kenda, which did very well for us on the pup. These are worn at 7500 miles.
    2) DH has to replace one of the dividers he made for the storage spaces over the bed, it detached at some pint last summer (one large space, 3 doors, dividers are handy)
    3) Make a list of what is in each cupboard or storage area. Never did this on the pup, since many of the boxes and supplies were moved at each set-up/take-down. While we do have to move some things to a stable place for on the road, most things have a permanent place. After a season in the TT, when we moved things around as we found positions that worked better, I think I can make lists - I forget where some of the lesser used items are squirreled away. (For instance, the box of repair-type clips and Velcro, hiding behind the p-trap of the one and only sink.)
    We've been making plans and reservations in the last couple of days. Some may be subject to change, but at least we have reservations in a couple of places that fill up quickly.
  11. jmkay1
    3,057
    462
    Dreaming of possible mods wishing I could open it up and take note of anything I need. But alas it sits in a grassy field with the ground so saturated that only a farm tractor could access. Trailers sinking into the soft earth I sit praying I will be able to pull it out come spring. Still need to find a battery tender/charger. Just not sure if my current battery is recoverable. It was siverely discharged when I bought the unit.
  12. vagov
    vagov Well-Known Member
    3,752
    101
    Aug 13, 2012
    Pittsburgh, Pa
    Joanne. Take your battery to auto zone they could test it, you may be better off buying a new one. At least you will know the history on it. Just my thoughts.
  13. silvermickey2002
    4,092
    82
    Sep 11, 2008
    Morris County, NJ
    It's 10 degrees (F) outside and just remembered to pull the battery out of the pup and put it in the basement. Will put it on the charger tomorrow when it's room temperture!
  14. RedAggie03
    RedAggie03 New Member
    77
    Apr 26, 2015
    I installed a digital thermostat for my heater.
  15. money pit
    money pit What could be so bad??? We are camping!!!
    613
    Oct 5, 2014
    [:)C] installing new roof with a new to me AC unit. I will be ordering new canvas by the end of the month! woooot!
  16. jnc
    I put a big pile of snow in front of it with a plow truck. It is official winter is here and she aint movin till spring!!
  17. tzmartin
    tzmartin Active Member
    624
    127
    Sep 9, 2015
    Got a bal leveler for 40 bucks shipped to me from Amazon. It was barely used awesome deal I think.
  18. PointyCamper
    PointyCamper Active Member
    459
    73
    Nov 25, 2015
    What did we do for our camper this month?
    Does CAMPING in it count?
    If so, we did a New Years stint at the beach!
    Love me some furnace. Actually the weather was nice.
    [ALPU] [TV]
  19. sespe
    sespe Member
    166
    Sep 23, 2015
    Went camping on the beach last night (the left coast). With the PUGs on we ran the heater once and stayed warm all night. Surf was up pretty high as we left today.
  20. kitphantom
    10,763
    318
    We got the campsite reservation made for our Colorado trip, which includes the entire Rally time.
    Went into the TT to check on conditions - no rodents, leaks, etc. We have two containers of Damp-rid, which are still dry and loose, even after two solid weeks of snow and ice.
Thread Status:
