Soaked—installing canvas
Discussion in 'General Weather Forum' started by Bhut2180, Jun 11, 2019.
  1. Bhut2180
    Bhut2180 Member
    30
    Apr 30, 2019
    i live in the Orlando area, notorious for mid day showers, well I pushed my luck too far and after getting just one panel up the deluge began full force. It soaked the interior, any suggestions or concerns when opening it back up to dry out????
    Thanks all
  2. fourhallatts
    fourhallatts Active Member
    867
    212
    Jul 18, 2015
    North Syracuse, New York
    Get it open asap. The sooner it can dry out the better. Good luck!
    Bhut2180, PopUpSteve and 1380ken like this.
  3. Bhut2180
    Bhut2180 Member
    30
    Apr 30, 2019
    I was able to do that thankful not as much water as I thought got it, toweled off all the water, then closed it back up for a second round of showers
  4. WrkrBee
    WrkrBee Well-Known Member
    1,764
    640
    Multiple fans working together to spin the air in the camper (like a vortex) and a vent fan taking the moisture out. The faster the air, the higher rate of evaporation. We tested this at work for drying rates.
    Bhut2180 likes this.
  5. jmkay1
    4,332
    1,279
    Agree with the above. Lots of fans blowing to circulate the air. My biggest worry for you will be the mattress. Foam can take a long time to dry and worse moldy if not given the needed circulation to dry throughly. Seeing as your matteress probably got the brunt of the water you need to be sure that drys very well before it's closed up.
  6. Bhut2180
    Bhut2180 Member
    30
    Apr 30, 2019
    Thankful the mattresses are still in their boxes brand new. It actually dried quickly after towel drying it and letting it be open after the second storm came through, thanks all for the advice
