Spongy floor in 85 Coleman
Discussion in 'Roof/Floor Repair & Maintenance' started by Sharonjh, Jan 16, 2017.
  1. Sharonjh
    Sharonjh New Member
    29
    Aug 9, 2016
    Has anyone repaired a spongy floor in their camper. The ply wood is in perfect condition, it's just the foam middle that has compressed. I read some people have had success with drilling holes and using expanding foam.
  2. Sharonjh
    Sharonjh New Member
    29
    Aug 9, 2016
    Update for anyone else that has spongy floors. I just finished repairing my flooring. Used the expanding foam and drilled in some 8mm dowels at 100mm apart. It seems to have done the job. Then I installed some vinyl over the top. I'm really happy with the result.
  3. eoleson1
    eoleson1 Well-Known Member
    1,674
    336
    Jul 5, 2011
    Macomb County Michigan
    The new floor looks great! I have never heard of foam under the floor. Who manufactured your pop up?
  4. Sharonjh
    Sharonjh New Member
    29
    Aug 9, 2016
    It's a Coleman. They have foam sandwiched between two pieces of plywood.
  5. eoleson1
    1,674
    336
    Jul 5, 2011
    Interesting. Probably makes for a warmer floor on cold mornings!
  6. thethird152
    thethird152 Active Member
    612
    98
    Feb 1, 2015
    Mt Pleasant, MI
    Looks wonderful!
  7. PWard
    PWard New Member
    Jul 8, 2018
    This looks great. We are new to PUP. Purchased a 2007 Rockwood HW276. There is a spongy area at the entrance door. We're hoping to just replace the bad wood with 3/4" marine plywood (probably 2'x2' area) and then putting down new vinyl. We're just trying to figure out if we'll need to remove all the cabinets in order to install new vinyl. Our unit has a small slide-out for the dinette. Any comments?
