storage door hinge replacement
Discussion in 'A-Frame PopUps' started by Sharyn Dagher, Jul 2, 2018.
  1. Sharyn Dagher
    Sharyn Dagher New Member
    Jul 1, 2018
    We need to replace the damaged hinge on the front storage box side access door and we have not been able to find this part online. Any suggestions on where we might find this. We have a 2000 Coleman Bayside Elite.
  2. Sjm9911
    2,344
    889
    I'll look at .one tomorrow, but isn't it a piano style hinge?
  3. nineoaks2004
    6,005
    2,204
    Graceville, Florida
    You can get a piano hinge at most home improvement stores, they come in different sizes and lengths, make sure it is the right size. Some are riveted so you may have to drill them out (do not use a bit to large. and then re-rivit the hinge back on, if you do not own one a hand riveter is cheap but make sure you get the tight size and length of rivets.
    Good Luck and Happy Camping
  4. Sjm9911
    2,344
    889
    I was never good at rivits myself! If that's too intimidating, bolts and nuts might work with a backer strip. Or they sell special flush mount nuts, if you need a flat surface, I haven't look at that part of my camper, as it works!
  5. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
  6. Raycfe
    14,007
    951
    awelcome.jpg from the Connecticut shoreline.
  7. Raycfe
    14,007
    951
    I think they are talking about the side access door hinge. It plastic and breaks easy. If you do not find one I have a new one someplace that I never used.
  8. Sharyn Dagher
    Jul 1, 2018
    Yes I am talking about the side access door and it is plastic. If you have an extra one I would be happy to buy it from you.
  9. Raycfe
    14,007
    951
    PM me the address I will send it out on Saturday
