Stripping and reseasoning cast iron.
Discussion in 'Pots, Pans, Grills, Other Cookware / Cleaning & Fo' started by Dusty road, Feb 19, 2019.
  1. Dusty road
    Dusty road Active Member
    730
    54
    Feb 28, 2016
    Conneaut, Ohio
    I've had good results stripping ci with a lye bath but now I'm considering putting together an electrolysis tank because it also removes rust as well as old seasoning. Does anyone have some tips/tricks or suggestions? Also going to try using Crisbee to season my ci with. Has anyone used it before?
  2. Sjm9911
    2,327
    886
    Get evapor rust. Safer , eaisier, and less complex. In the past i just used salt and made a paste, scrubbed it real good then a good coating of oil ( forgot what i used) . Ot didnt season great, so i cooked a lot of bacon in it. That did the trick. My pans were badly rusted, but came out great. Found them in a house sale, cost was free.
  3. nineoaks2004
    5,983
    2,194
    Graceville, Florida
    I have always used the method that was taught to me by my Dad and Grandfather , I start a fire with oak or other hard wood, then put the cast iron into the fire, when it cools down I then re season the pan in an oven.
    Dusty road likes this.
  4. Overland
    Overland Active Member
    158
    84
    May 1, 2013
    Bristol, Pa
    There's a guy on another forum who's a cast iron junkie.. he links this video for cleaning often. The guy has several video's on differing steps to cast iron restoration.. perhaps it helps?
    I have some I need to reseason, a newer Lodge I originally did with vegetable oil before I knew better. I'll be using Crisco paste.. but collectors recommend flakseed oil.
    Here's another source of info some might find useful.
    http://sherylcanter.com/wordpress/2010/01/a-science-based-technique-for-seasoning-cast-iron/
    PointyCamper, Dusty road and Sjm9911 like this.
  5. tombiasi
    4,745
    565
    I have done several. When I did I had access to a bead blaster that took them down to bare cast iron. I’m not sure what I would do now to get the old stuff off but the seasoning procedure would be the same.
  6. Bowman3d
    Bowman3d Active Member
    730
    219
    Apr 13, 2015
    LaLa land
    I’m with SJM9911, Evapo-rust . I use it to clean rust off rusty lantern parts. It’s nontoxic and just takes the rust off and leaves the good metal alone.
