Stuff cooked in my new pan tastes funny
Discussion in 'Dutch Oven Cooking' started by souvafam, Feb 26, 2017.
  1. souvafam
    souvafam New Member
    25
    Mar 8, 2013
    I have a new to me cast iron pan my mom found for me at a garage sale. I scrubbed it many times but everything cooked in it tastes "off". Also the lid has an almost waxy coating on it. It is in great shape and seems seasoned but now I am leery of using it with the strange flavors. I have no idea what they used on it so now I would like to strip it and start over. I know how to re season but any suggestions on how to strip it clean? Any help would be appreciated! I really like the pot and it's exactly what I was looking for. It's about the size of a 12" skillet but with tall sides, a regular handle and small handle on the other side, no brand on it though.
  2. tombiasi
    tombiasi Active Member
    The only time that I did that I sand blasted. If you know a place that can do that it's pretty short work for them.
  3. world traveler
    world traveler Member
    191
    Oct 23, 2015
  4. tombiasi
    Burning it off would work, it will stink up your house and sand blasting is faster.
  5. wunderfog
    wunderfog New Member
    72
    Mar 24, 2015
    I'd put it on a hot grill (empty and upside down) for a couple of hours, then scrub and start your seasoning from scratch. The grease used last might have gone rancid.
  6. SteveP
    SteveP Member
    395
    If you have a fireplace build a medium fire. Preheat the pan until it is almost to hot to handle. and set the pan upside down, and the lid, in the middle of the fire. Leave it till the fire burns out and the cast iron cools. That should burn off anything they may have put on it and hopefully won't set off your smoke alarm.
    If you don't preheat the pan there is some risk it might crack.
  7. tombiasi
    @nnymom,
    Where are you located in NY?
  8. nfisherman
    nfisherman Member
    325
    Apr 23, 2005
    Illinois
    I have stripped and reseasoned several cast iron pans. I soak the pan in 1 pound of lye in about 4 gallons of water. An overnight soak does it. You have to be careful with lye but it strips the pans beautifully. You need to rinse and reseason immediately because the stripped pan will start to rust as soon as it dries. Barkeeper's Friend powder works well for scrubbing any rusty spots.
  9. vagov
    vagov Active Member
    3,413
    Aug 13, 2012
    x2. Then use 2 coats. Instead of 1 heavy, put 1 light coat on, rub off as much as you can, turn upside down on gas grill as hot as you can get it, bake 1 hour, cool down to touch and do it a second time
  10. Haybale
    2,072
    Aug 22, 2013
    San Diego via MN
    Put it in your self cleaning oven and let it run a full cycle. I do that with all new or new to me CI.
    Does the odd taste seem fishy or spoiled oil?
    First I would scrub is with dish soap and a plastic brush and see how that goes.
