Tankless Water Heater ?
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by leonoro, Mar 10, 2019.
  1. leonoro
    leonoro New Member
    Mar 10, 2019
    We are working on the option list for the next RV and I had a question about the water heater.
    We currently have a 10g dual gas/elec water heater that works great. It's just the 2 of us and we almost never use the propane to heat water and almost never run out of hot water on electric.
    The option of tankless is appealing but I'm pretty sure all of them are gas fired and that would consume a fair bit of propane that we aren't using now.
    Is there such a thing as an electric tankless water heater or they all gas?
    Pretty sure I already know the answer
  2. Waltair
    Waltair New Member
    Mar 10, 2019
  3. mstrbill
    mstrbill Active Member
    659
    135
    Mar 17, 2013
    Austin , Texas
    12 Amps of it, or almost half of a 30 Amp shore connection.
  4. Sjm9911
    2,327
    886
    Just a thought, ive fired up my propane water heater for washing, and showering, rhen sut it down. It heats up fast. After im done i turn it off. So not cycling to heat the water. I cant see that using much propane. Mine is just propane fed. No volts.
  5. mattlreese
    mattlreese Active Member
    131
    31
    Sep 6, 2017
    Tankless electric heaters at 110V are only good for small point of use cases. A separate hot water tap at a sink as an example.
  6. tdiller
    tdiller Active Member
    235
    77
    Aug 25, 2016
    Tankless water heaters also slow the flow down. They need to do this so that the water running across the heater element has time to warm up. I have one in my barn for washing horses and for that it's fine but I don't think I'd like it in my house or camper for human use.
