Thermostat two wire wiring.
Discussion in 'Wiring' started by Samuel T, Mar 13, 2018.
  1. Samuel T
    Samuel T Member
    37
    Feb 25, 2018
    C8822901-E293-4E2D-BE08-3D0305DF55A9.png i got the furnace running the other day by bypassing the thermostat. It was missing pieces. I was told to replace it with another low voltage thermostat. I was going to buy another hoenywell but I scored one a little cheaper on Amazon. Hope I didn’t scare myself though.
    The Honeywell was wired with the red wire to the R terminal and the white wire to the W terminal.
    The new one however does not have an R terminal. So I guess my questions are 1) is this thermostat compatible? And or 2) does the red hook up to a different terminal. Here are the terminals provided. 7C957F09-04B1-4941-8428-804B93A17543.png
  2. myride
    myride Well-Known Member
    736
    303
    May 14, 2015
    Edmonton, AB
    My electrical is almost as good as my plumbing expertise (Sh** rolls down hill and payday is Tuesday) BUT my uneducated guess would be the R(H) terminal, think that's "hot"...I'd check mine but can't pop it up at the moment.
    Samuel T likes this.
  3. jnc
    can post a close up pic of the back of the unit?
  4. Samuel T
    Samuel T Member
    37
    Feb 25, 2018
    Sure can. On my way home now!
  5. joet
    3,011
    318
    Wire it according to the instructions that came with it.
  6. Samuel T
    Samuel T Member
    37
    Feb 25, 2018
  7. jnc
    connect your Red to Rh and your White to W and all will be fine
  8. Samuel T
    Samuel T Member
    37
    Feb 25, 2018
    Thank you so much.
  9. jnc
    NP
  10. Samuel T
    Samuel T Member
    37
    Feb 25, 2018
    Update. All worked good! Red to (Rh) that was the money maker! $14.00 on Amazon... pictured with Honeywell. E937A079-1C29-4C3F-A2D0-4EF359F89A76.jpeg E65FA9FE-2D0F-48B1-A9A9-AB14B999A28F.jpeg
    jnc likes this.
  11. neighbormike
    1,100
    452
    Oct 6, 2012
    WI
    Looks good Samuel! May need to update mine one of these days!
  12. Samuel T
    Samuel T Member
    37
    Feb 25, 2018
    Thanks! I can say I’m one toggle switch install away from being done!
