Timber Tote Logs
Discussion in 'Campfires and Firewood' started by Martlee, Nov 17, 2018.
  1. Martlee
    Martlee New Member
    Aug 15, 2016
    Anyone have any experience with these timber tote logs that you can get from Lowes and other places? Seems like an easy/lazy way to spend a couple of hours in front of a fire.
  2. PopUpSteve
    PopUpSteve Administrator
    17,483
    726
    Dec 22, 2002
    Malvern, PA
    I've seen those but never used one. Always wondered how good they work.
  3. generok
    generok Well-Known Member
    2,202
    370
    Feb 7, 2013
    Anchorage, AK
    The concept, called a Swedish Fire (Torch) Log, works REALLY well. You can make them yourself if you have some patience. Here's one video:
    I have built them myself out of pallets. I took the 4X4 feet off pallets, drilled the shaft and side hole, then attached some pallet planks to the side, and they burn like CRAZY! I stuck a cotton ball with Vaseline inside, and just hit it with a fire stick and BAM, instant fire. I used them to start a fire usually.
    I use a LP fire pit now, but sure, in concept, they actually work pretty good.
    Fred1diver likes this.
