Tire replacement recommendation?
Discussion in 'Tires / Brakes / Bearings / Axles' started by ForTheLoveOfNature, Apr 12, 2018.
Tags:
  1. ForTheLoveOfNature
    ForTheLoveOfNature New Member
    Apr 11, 2018
    Hello! We just bought our first PUP last week, and I have really appreciated all of the learning opportunities here!
    We are making a list of needs before taking her out, and tires are #1. The tires on it are the originals, manufactured in April 1997! Yikes! We aren't experienced in purchasing trailer tires and would REALLY appreciate your recommendations!
    Our PUP is a 1997 Coleman Fleetwood (yes ABS roof; already repaired). It weighs 2090 lb. and has a GVWR of 2390lb. Any recommendations on type, brand, place of purchase, etc?
    The current tires read:
    B78-13ST
    ST175/80D13
    Load range c. Max load 1360lb
    Tread area 4 plies, side wall 2 plies nylon
    50PSI MAX (rim and tire)
    Thank you all so much!
  2. joet
    3,666
    554
    Believe it or not, you will find the best price at wallys, with free shipping, and myself I would replace with a load range D tire. Just a little extra insurance
    ForTheLoveOfNature likes this.
  3. Sneezer
    1,307
    373
    Wal Mart, Tractor Supply, Northern Tool, etc. I bought mine from Northern Tool but that was mainly because I was in a pinch due to a blowout on a trip, and I couldn't be too choosey. Get radials if you can, and go up to the next load range (D) just to be safe.
    While you are at it check the hubs and axle bearings. If it has original tires on it there is a good chance the bearings need repacked.
    Congrats on the new pup!
  4. BikeNFish
    BikeNFish Well-Known Member
    1,924
    1,077
    Apr 24, 2017
    Maplewood, MN
    Get radials and don't skimp. More is better. And like mentioned, bearings are next!
    Congrats on your NTU pup!
  5. Mamie
    Mamie Active Member
    838
    109
    Sep 11, 2017
    LA - Lower Alabama
    I don't remember where I read it, but it was recommended to have the tires balanced. I didn't know you could mount tires without them being balanced.
    I just got new tires for my truck, I know the ones on it had been on there since 2011, but I bought them from Walmart and had them shipped to Express Oil to be mounted. It wasn't cheaper, but EO is closer.
  6. shfd739
    shfd739 Member
    530
    Apr 16, 2011
    My choice would be the Carlisle Radial Trail HD. Good for 81mph and your size comes in a D load range which will give you an extra 420lbs of tire capacity. Or keep the load range C which is still more than your trailer is rated for.
    We ran these same tires on our Coleman and loved them. They towed great and never needed more than 2-3psi of air added no matter how long they sat between trips.
    giadiep and ForTheLoveOfNature like this.
  7. xxxapache
    2,566
    627
    You can buy that size already mounted on new wheels shipped to your door for $110-$120 per pair from several eBay vendors.
  8. ForTheLoveOfNature
    Apr 11, 2018
    Thank you! Yes, bearings are on the list. Just nervous as I've never undertaken a project like that! Neither of us are mechanic minded, but I'm sure we can find some helpful YouTube videos.
  9. ForTheLoveOfNature
    Apr 11, 2018
    Good to know! We have a Walmart just a half mile away.
  10. ForTheLoveOfNature
    Apr 11, 2018
    Thank you, everyone! I really appreciate your time and care in responding to my question. I feel much more confident now about making a prudent tire choice, and what things to be sure to include on my checklist. :)
  11. Old_Geezer
    Old_Geezer Well-Known Member
    2,428
    33
    Sep 29, 2009
    Southwest PA
    I would seriously consider new wheels so I could up the size to a 205 -14" and then go with the Goodyear Endurance ST. May or may not be an option as it would be dependent on enough clearance, but they'e an awesome tire.
  12. joet
    3,666
    554
    Be careful when buying tires off e-bay. Read the description close and pay attention to the production dates.
    terry1419 and ForTheLoveOfNature like this.
  13. xxxapache
    2,566
    627
    I have bought trailer/tire combos off of eBay. The tires were less than a year old. I have probably bought 30 tires online in the past 5 years. I haven't had any problem with getting old tires.
  14. Rusty2192
    Rusty2192 Active Member
    684
    199
    Jul 30, 2014
    Kentucky
    I second the notion to try to get something rated for 82 mph, if you can find them in your size for a reasonable price. I don’t tow my pup at 80 mph, but it’s really nice to be able to cruise at close to 70, which is the speed limit on the interstates around here. Even at that speed I feel like I’m getting run over, unless I can find a nice slow semi to tuck in behind. Plus it allows for a little extra margin if I need to speed up a bit to complete a pass of a semi before backing back down to a reasonable speed. Most trailer tires are only rated at 65 mph.
  15. xxxapache
    2,566
    627
    ForTheLoveOfNature and Rusty2192 like this.
  16. giadiep
    giadiep Active Member
    340
    133
    Sep 5, 2015
    Syracuse, NY
  17. kcsa75
    kcsa75 Well-Known Member
    1,919
    731
    Sep 9, 2013
    Kansas City
    I bought Kenda radials mounted on white spoke wheels at Wal-Mart for, if memory serves me correctly, about $65 each. I had them delivered to the store then paid a few bucks to have them balanced in the tire shop.
    I wouldn't worry too much about buying a high-dollar tire. On a boat or Pup, tires are most-likely going to rot before you wear them out. [:)C]
  18. Jeep Guy
    Jeep Guy Active Member
    125
    64
    Mar 7, 2018
    Check the tire prices at Etrailer.com. They have your size already mounted on a new rim for $78. I recently bought two new entire wheels from Etrailer.com (tires already mounted to new rims) and they had the best prices. I went to Tractor Supply, Walmart, and my local tire stores and Etrailer.com was about $22 cheaper per wheel than the other stores. And you get free shipping on orders over $100.
    https://www.etrailer.com/dept-pg-Tires_and_Wheels-sf-Tire_with_Wheel-pc-13_Inch.aspx
  19. joet
    3,666
    554
    Also check Eastern Marine and Wally. com. The stores can't get what Wally has online. They both have better pricing
    ForTheLoveOfNature and Jeep Guy like this.
  20. ForTheLoveOfNature
    Apr 11, 2018
    Thank you everyone! Your feedback was incredibly helpful and appreciated! Yesterday evening I ordered this, and I am glad to have the peace of mind that a few different people recommended the Carlisle. I did consider going up in size for a little more clearance, but with only 2" clearance between the current tires and frame, I decided to play it safe and keep with the 13's. Thank you again!
    https://www.americastire.com/buy-tires/carlisle-radial-trail-hd/p/27240
