Towing with a manual
Discussion in 'On The Road' started by Hockeybjj, Jul 11, 2017.
  1. Hockeybjj
    Hockeybjj Member
    61
    Jul 11, 2017
    My tow vehicle is a 2010 Subaru Outback with a little 2.5i 4 cylinder and manual 6 speed transmission
    Trailer capacity is listed at 2700 pounds, but tongue weight at 200 pounds and so the 10% rule should put me at an actual limit of 2000 right? My pop up we just bought is 1750 pounds empty, and we plan on leaving it mostly that way when pulling it, having camping tubs of gear kept in the Outback.
    Anyway, on the highway I leave it in 5th gear instead of 6 and go 60-65 tops which is 2800-3000 rpms. When shifting, instead of shifting at 3k I'm letting it climb a little higher to 3500 so that it drops down to 2k after the change instead of ~1600
    Does this sound right? I'm very used to pulling but this is my first with a manual and I've only been driving a stick for a little over a year anyway and wondering what the best method to minimize the extra strain on engine and drivetrain is with pulling something on the upper end of its pulling limit. Thanks
  2. giadiep
    giadiep Active Member
    212
    70
    Sep 5, 2015
    Syracuse, NY
    Sounds like a good plan. Keeping it in 5th should help protect the transmission. The 6 speed is so much better than the cvt
  3. Strikeouthhh
    Strikeouthhh Member
    98
    Jun 11, 2015
    St. Paul
    That's about what I did with my TDi - giadiep's right - wouldn't do it with the DSG automatic either.
    Hockeybjj likes this.
  4. Lloyd B
    Lloyd B Member
    95
    24
    Nov 3, 2016
    Columbiaville, Michigan
    I agree with the others, you got this. Just don't lug the engine.
  5. xxxapache
    1,990
    280
    One of my TVs is an underpowered 4 cylinder 5 speed. I have towed at it's near Max capacity for over 20 years. On a steep grade, I just downshift and let the engine scream. It's got 206k miles on it and still has the original clutch.
  6. GreatBigAbyss
    GreatBigAbyss Active Member
    134
    60
    Apr 12, 2017
    Manitoba
    I wouldn't worry so much about it. As long as you're not lugging the engine, you should be okay. 4-cylinder engines are quite torquey at low rpm's, so running it in 6th (especially on the highway) shouldn't be a problem. Remember, when you're on a flat highway, you're not so much worried about weight, but rather with windage. Since pop-ups are usually under the roofline of the tow vehicle, windage isn't too much of an issue.
    You'll know if 6th gear is geared too high because you won't be able to maintain speed on the highway. IF that is the case, then drop it down to 5th. I doubt it, though. 6th should be okay.
    If you're in the hills, definitely rev the engine a little higher than you normally would in order to take advantage of the powerband.
    I towed a 1000lb dry-weight pop-up complete with stuff inside it, and the whole family and a full trunk in a 4-cyl CVT Altima. The CVT would drop into its highest ratio on the highway, and I never noticed any undue strain on the engine. In hills, it would simply pick a lower ratio than normal, and it never felt underpowered.
    You'll be fine.
  7. seldomseen380
    seldomseen380 New Member
    22
    Jan 12, 2007
    Canton, Georgia
    1. Manual Transmission...[8D]
    2. Regular Shifting Automatic Transmission W/ External Oil Cooler...:grin:
    3. CVT Transmission...[XX(]
  8. petefuller
    petefuller New Member
    Aug 27, 2017
    shift it when the tach and engine sound says shift, dont over rev or lug the engine and you should be fine for years.
    Dont forget to get the transmission oil changed at spec'd intervals, somehow they seem to get forgotten.
  9. Lug_Nut
    Lug_Nut Member
    61
    21
    May 29, 2016
    Mt. Wachusett area, MA
    "Lugging" is subjective. What some might consider lugging is considered by others to be a 'sweet spot'.
    One can be 'lugging' an engine at 1200 rpm, or at 4200 rpm.
    In a nutshell: Drive the manual in the highest gear that allows you to travel at your desired speed. If you can't maintain that speed, even though your right foot is on the floor, then you are "lugging" no matter where the tachometer needle is pointed and should shift down a gear.
    Oh, my screen name? It's quite appropriate.
  10. BelchFire
    1,385
    102
    Mar 29, 2012
    SE Georgia
    My favorite vehicle of all time was a 1988 Jeep Cherokee with a 5 speed (T-5). That thing was gorilla strong! I had a 23' SeaRay on an enormous galvanized trailer and it would pull it anywhere I wanted to go. When it got too many miles (or so I **thought**), I sold it and bought a '93 with an automatic. Worst mistake I've ever made. The auto with 4.0HO wouldn't pull nearly as well as the manual.
    As others have said, it's all in the use of the engine RPM. I mostly towed in 4th unless I was in Florida on a flat road or interstate, then I would use 5th judiciously. You've gotta know your engine's torque curve and stay in the middle of it.
