Trailer Tongue Jack
Discussion in 'Miscellaneous Repairs & Maintenance' started by liv4mtns, May 1, 2010.
  1. liv4mtns
    liv4mtns New Member
    51
    Jul 27, 2009
    Bozeman, MT
    Does anybody know if there is a manufacturer that makes a tongue jack with a pneumatic wheel instead of those hard rubber types?
    Kevin.
  2. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
    I have never seen one. Can I ask why? If it is for moving across the ground easier I can tell you from experience it won't be. I had hard rubber tires on a dolly and rough terrain (rocks in the gravel driveway) to roll across so i replaced them with pneumatics.Went back to the hard rubber after the first attempt to roll across the drive. I found I could only take half the weight on the dolly with the inflatable tires.
  3. liv4mtns
    liv4mtns New Member
    51
    Jul 27, 2009
    Bozeman, MT
    Hacksaw...that's exactly what I was getting at. I'll nix that idea for sure. Thanks. So are you against a trailer dolly as well for moving and turning a PUP in a campsite?
    Kevin.
  4. Hacksaw
    1,875
    Aug 23, 2009
    No I am all for a trailer dolly. The dolly I was talking about I guess would be more commonly called a 2 wheel cart. The thing I would like to see is a tongue jack with a large diameter wheel (12" or so) That would move across the ground like it was on rails.
  5. jim1999
    jim1999 New Member
    1,645
    Jul 8, 2008
    East Central Illinois
    I agree Hacksaw. Even an 6-8 inch wheel that had a decent foot print would help big time in comparison to those narrow wheels. What would be really nice too if they made them in the flat free variety. IMHO it is not so much the diameter of the wheel as it is how narrow they are.
  6. liv4mtns
    liv4mtns New Member
    51
    Jul 27, 2009
    Bozeman, MT
    Would something like this work?
    http://www.marathonind.com/flat-free-tires/wheelbarrow-tires.htm
    Not sure if it would work or not.
    Kevin.
  7. Hacksaw
    1,875
    Aug 23, 2009
    Yeah a wider tire would help a bunch. I have considered putting one on each side of the jack and using some type of spacers to make it clear the tongue. I have rather soft ground so it ruts very easily those ruts are why I want a 12" wheel.
  8. grim509
    grim509 Member
    111
    Feb 2, 2010
    It'd be much easier and cheaper to use a trailer dolly. I picked one up at harbor freight for under $50. It makes moving the camper sooo much easier, especially for me with my bad back. I can even walk upright while moving it. I have extremely sandy soil here, and it still moves almost effortlessly.
  9. You-And-I
    You-And-I Ozarks Ɯberland Basecamp
    861
    Jan 3, 2007
    St. Louis, MO
    liv4mtns,
    I do not have pneumatic tire on my trailer jack, but I do have Twin Wide Track wheels on our jack.
    Maybe this would work for your needs. Great Product
    Check it out, hope this helps!
    Alan
    Click Here: F2 Jacks - Twin & Wide Track
    Note: F2 Jack about half way down the page-Product #1413080334
  10. liv4mtns
    liv4mtns New Member
    51
    Jul 27, 2009
    Bozeman, MT
    Thanks Alan for the link. Those are very interesting jacks.
    grim509, the trailer dolly is on my to get list. Thanks.
    Kevin.
  11. mattyj
    mattyj Member
    58
    Jun 9, 2009
    Maine
    I have been thinking about this for a couple weeks now and decided to look into it. I found alot of posts on the trailer dolly, but for me, thats to much to pack for campgrounds. I have an idea that I think will help, similar to hacksaws idea. I have a couple 8" or 10" pneumatic tires. I'm going to try it out and I'll post pics ASAP.
    happy camping
  12. vincent228
    vincent228 Member
    65
    Jul 29, 2010
    you would think it would be easy to find.
    i did see some really good jacks with decent wheels at harbor freight
    could this work ?
    http://www.harborfreight.com/automotive-motorcycle/trailer-jacks/1500-lb-capacity-dual-wheel-swing-back-boat-trailer-jack-67500.html
  13. mattyj
    mattyj Member
    58
    Jun 9, 2009
    Maine
    So here's my idea....this was just a trial run to see if it has potential.
    Here's a link to a couple more pics and info.
    http://picasaweb.google.com/mattyjdi/HitchWheel?feat=directlink
  14. ogeer3
    ogeer3 New Member
    1,115
    Oct 14, 2004
    Grand Prairie,TX,75052
    mattyj,
    That is exactly what I have been thinking of trying for some time now. I never use the single hard rubber wheel that came on my trailer because I can not move the trailer on it. How well does it push across the yard and grass or over small bumps like say a 2x4? Have you tried it with wet or muddy ground? I will be trying this very soon.
  15. mattyj
    mattyj Member
    58
    Jun 9, 2009
    Maine
    I haven't had a chance to put it to the test yet, need to drill out the caster and get a 5/8" bolt first.
  16. Old#7
    Old#7 New Member
    Jun 26, 2010
    Any More insight to this solution. Did it work or not. I love the idea!
  17. mattyj
    mattyj Member
    58
    Jun 9, 2009
    Maine
    Yes, I used it all last year and still using it this year. Perfect for turning camper 90 degrees onsite. I would like to get rid of the caster portion and have the axle directly below the pivot point. That would make turning a little easier. It helps to keep tire pressure up to 40+.
    Happy Camping!
  18. GCHIKER
    GCHIKER New Member
    53
    Sep 29, 2010
    If you put the axle directly, or too close to the center of the jack post, it won't rotate easily when you try to change directions while moving the camper. The "caster" does this automatically.
    Think about shopping carts.
  19. Rodger D.
    Rodger D. New Member
    748
    Sep 29, 2010
    Home Worker's Club
    I could modify what I have now with an like dual tire design
    that Matt has shown for the same problem has happened here
    too.
  20. 94-D2
    94-D2 Happy Campin'
    2,278
    127
    May 21, 2010
    Sutter Creek CA
    You could remove the caster offset and add a steer handle, like on an outboard boat motor. Tat way you could direct whatever direction you want and not depend on the offset to provide directional leverage.
    Justa thought...
    J
