Trailer Tongue Jack
Discussion in 'Miscellaneous Repairs & Maintenance' started by liv4mtns, May 1, 2010.
  1. jrclocks
    jrclocks Member
    585
    Jun 24, 2008
    Here's how I move my camper.
    It uses a pair of pnuematic tires and fits on the bottom of the jack.
    The handle acts as the tiller for direction and has the controls on it.
    It moves about 8 feet/minute.
    JR
  2. BigBaron
    4,583
    Jun 21, 2012
    For those heavy campers that is a great idea! I love the double tire axle dolly. Thanks for the info!
  3. mattyj
    mattyj Member
    58
    Jun 9, 2009
    Maine
  4. BigBaron
    4,583
    Jun 21, 2012
    I'm going to get the parts and build mine before our new trailer even gets here! Thanks for posting this! I can't imagine lugging around that thing from harbor freight.
  5. Raycfe
    14,409
    1,074
    Mine has a 18 hp engine ....... lawn tractor ....
  6. BigBaron
    4,583
    Jun 21, 2012
    Re: Re: Trailer Tongue Jack
    Must be a bear to get that in the trailer! :eek:
  7. inacoma
    inacoma New Member
    Apr 15, 2013
    I just built this and it is going to work really well when I get air in the tires. Lol. Also I may use or make some sort of spacer to widen the tires out a bit farther so I don't have thread sticking out the side to catch an ankle on. Or cut it off. Not sure what approach I want to take yet. Trying to decide if the extra width will help or hinder the leverage effect of the offset wheels. Also I am going to keep the offset there so that if I want to unthread the handle portion and just just the wheels I still have that option. Also going to out some spare bike grips on the handle section and paint it up nice. Thanks for the great idea! [​IMG]
  8. BigBaron
    4,583
    Jun 21, 2012
    Looks good! Why not put nuts inside of the wheels?
    I have everything to build mine except 3/4" all-thread! I can't find it anywhere here! [LOL]
  9. inacoma
    inacoma New Member
    Apr 15, 2013
    I am not using all thread. I just got a 5/8x10" grade 5 bolt. And if you use nuts you have the potential of the pressure of the turning tires to tighten the nut up against the hub and acting like a brake when it gets tight enough. But the more I think about it, I actually think they on a leverage side of things, keeping the tires right next to the legs might be better.
  10. 94-D2
    94-D2 Happy Campin'
    2,278
    127
    May 21, 2010
    Sutter Creek CA
    Drill a hole in the bolt, put a castle nut and coter pin in it. If you can't drill the hole, you can buy it any size you need. Looks good though.
  11. patfraley
    patfraley we're on a road to no where...
    156
    Apr 29, 2014
    Question.....went by Harbour Freight to look at wheels. 10" Neumatics are rated for about 300-350lbs. Is that good enough considering there will be two? Also, what size? 8". 10"?
  12. n2cruzn
    n2cruzn New Member
    648
    Oct 2, 2012
  13. patfraley
    156
    Apr 29, 2014
    Not really looking to spend $300 but thanks anyways
  14. rob2218
    rob2218 New Member
    1,549
    Feb 25, 2014
    Great product but is it overkill for a pop up?
  15. n2cruzn
    n2cruzn New Member
    648
    Oct 2, 2012
    not for me. i go up my driveway and then i have a 90 deg turn into backyard and then 180 it for on the way out. AND i dont know how to back up.....and it would be tight up the driveway......ohhh did i mention i do this by myself with 2000 lbs.
    then into the cg with ease.
    no not overkill [ALPU]
  16. rob2218
    rob2218 New Member
    1,549
    Feb 25, 2014
    can ya show us what it looks like on yer PUP?
    thanks.
  17. rob2218
    rob2218 New Member
    1,549
    Feb 25, 2014
    Saw the video....was wondering how the dern thing was put up when traveling.....awesome mechanism.....and I agree....it sure would beat that "back/forth" motion...but Iv'e gotten to be a pro a putting the hitch ball within 3/4" of the coupler......amazing what a little practice over and over can do for ya.
    Maybe if I was Leno I'd buy one.....or "when" I win the California lotto [:D] [SUN] [SUN] [SUN] [SUN]
  18. n2cruzn
    n2cruzn New Member
    648
    Oct 2, 2012
    it has 2 pins. 1 for verticle and another to turn it 90 deg for travel. it IS a bit heavy. will try to remember how to post a picture. oh and another thing....it has a tube within a tube for a base for quick adjustments
  19. rob2218
    rob2218 New Member
    1,549
    Feb 25, 2014
    I'm tellin ya.....looks pretty slick that doo-hickey
    if I were Jay Leno I'd be all over that like a monkey tearin' into a cupcake.
  20. CAMPERBOB
    CAMPERBOB New Member
    48
    Jun 13, 2014
    Hi
    I really want to do this mod as well, to help with manually moving the trailer at home on concrete surface.
    My original wheel assembly is a 1/2" bolt. The new tires are 5/8" hub. [?:~{]
    Did you have to drill out the holes on the wheel mount, or were yours already 5/8"?
    Do you think there is enough material there if I drill it out, or will that get too weak?
    I'm also considering using a 1/2" bolt and find something to use as a bushing to get to 5/8" for the wheels. Any suggestions?
